[ICEM] A simple question about length unit
Old   July 26, 2012, 14:20
Question A simple question about length unit
lnk
lnk
lnk is on a distinguished road
Hi everyone,
Here is the question. I designed my geometry in ICEM. I never specified the length unit. When i import the mesh to CFX, the length unit is defined automatically to meter which makes my geometry too large to have the correct simulation results. (My pipe is 4 cm long but it makes it 40 meters. So the pressure drop result doesn't make any sense. )May I ask how to set my geometry to the correct size without redoing it?
Best regards,
lnk
lnk is offline   Reply With Quote
Old   July 27, 2012, 04:23
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
When writing the mesh in ICEM, you can apply a scaling factor.
If you forgot to do so, you can still scale the mesh in CFX.
flotus1 is offline   Reply With Quote
Old   July 27, 2012, 04:26
lnk
lnk
Thank you very much. May I ask how to scale it at CFX?
Best,
lnk
Old   July 27, 2012, 04:27
AB
BrolY will become famous soon enough
ICEM is unitless. Simon already explained that in this forum, you should make a research.
But as Flotus said, you can scale your mesh when you export, or scale your geometry when you import it.
BrolY is offline   Reply With Quote
Old   July 27, 2012, 04:33
flotus1's Avatar
Alex
Right click on the imported mesh, choose "transform mesh" and select "scale" as the type of transformation. Isn't this in the manual?
Old   July 27, 2012, 04:34
lnk
lnk
But I can't scale it any more after I already imported the mesh, right?
Best,
lnk
Old   July 27, 2012, 04:45
flotus1's Avatar
Alex
Sure you can. See my last post.
Old   July 27, 2012, 05:01
lnk
lnk
Thank you very much, Flotus and BrolY. I searched 'length unit' at the 'help CFX-pre' but didn't find the answer for that. Now the problem is solved. Thanks!
Calculation of Drag Force per unit Length Mohammad Faridul Alam CFX 4 January 11, 2013 07:19
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 20:12
A simple question Chandra Shekhar Main CFD Forum 0 January 31, 2005 02:44
Starwatch problem and turbulence length unit Jiaying Xu Siemens 0 August 18, 2001 10:57
A Simple Question Thomas P. Abraham Main CFD Forum 3 September 6, 1999 18:19
