-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] A simple question about length unit (http://www.cfd-online.com/Forums/ansys-meshing/105277-simple-question-about-length-unit.html)
lnk July 26, 2012 14:20
Hi everyone,
Here is the question. I designed my geometry in ICEM. I never specified the length unit. When i import the mesh to CFX, the length unit is defined automatically to meter which makes my geometry too large to have the correct simulation results. (My pipe is 4 cm long but it makes it 40 meters. So the pressure drop result doesn't make any sense. )May I ask how to set my geometry to the correct size without redoing it?
Best regards,
lnk
flotus1 July 27, 2012 04:23
When writing the mesh in ICEM, you can apply a scaling factor.
If you forgot to do so, you can still scale the mesh in CFX.
lnk July 27, 2012 04:26
Thank you very much. May I ask how to scale it at CFX?
Best,
lnk
BrolY July 27, 2012 04:27
ICEM is unitless. Simon already explained that in this forum, you should make a research.
But as Flotus said, you can scale your mesh when you export, or scale your geometry when you import it.
flotus1 July 27, 2012 04:33
Right click on the imported mesh, choose "transform mesh" and select "scale" as the type of transformation. Isn't this in the manual?
lnk July 27, 2012 04:34
But I can't scale it any more after I already imported the mesh, right?
Best,
lnk
flotus1 July 27, 2012 04:45
Sure you can. See my last post.
lnk July 27, 2012 05:01
Thank you very much, Flotus and BrolY. I searched 'length unit' at the 'help CFX-pre' but didn't find the answer for that. Now the problem is solved. Thanks!
