July 26, 2012, 14:20 |
A simple question about length unit
lnk
Rep Power: 15 |
Hi everyone,
Here is the question. I designed my geometry in ICEM. I never specified the length unit. When i import the mesh to CFX, the length unit is defined automatically to meter which makes my geometry too large to have the correct simulation results. (My pipe is 4 cm long but it makes it 40 meters. So the pressure drop result doesn't make any sense. )May I ask how to set my geometry to the correct size without redoing it? Best regards, lnk Last edited by lnk; July 26, 2012 at 15:40. |
July 27, 2012, 04:23 |
Alex
Rep Power: 46 |
When writing the mesh in ICEM, you can apply a scaling factor.
If you forgot to do so, you can still scale the mesh in CFX. |
July 27, 2012, 04:26 |
lnk
Rep Power: 15 |
July 27, 2012, 04:27 |
AB
Rep Power: 21 |
ICEM is unitless. Simon already explained that in this forum, you should make a research.
But as Flotus said, you can scale your mesh when you export, or scale your geometry when you import it. |
July 27, 2012, 04:33 |
Alex
Rep Power: 46 |
Right click on the imported mesh, choose "transform mesh" and select "scale" as the type of transformation. Isn't this in the manual?
July 27, 2012, 04:34 |
#6 | |
lnk
Rep Power: 15 |
But I can't scale it any more after I already imported the mesh, right? Best, lnk |
July 27, 2012, 04:45 |
Alex
Rep Power: 46 |
Sure you can. See my last post.
July 27, 2012, 05:01 |
lnk
Rep Power: 15 |
Calculation of Drag Force per unit Length | Mohammad Faridul Alam | CFX | 4 | January 11, 2013 07:19 |
Question of Anil Date's SIMPLE method | universez | Main CFD Forum | 0 | November 18, 2009 20:12 |
A simple question | Chandra Shekhar | Main CFD Forum | 0 | January 31, 2005 02:44 |
Starwatch problem and turbulence length unit | Jiaying Xu | Siemens | 0 | August 18, 2001 10:57 |
A Simple Question | Thomas P. Abraham | Main CFD Forum | 3 | September 6, 1999 18:19 |
