-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Extrude mesh along curve (http://www.cfd-online.com/Forums/ansys-meshing/105481-extrude-mesh-along-curve.html)
clocter July 31, 2012 23:19
2 Attachment(s)
Hi all,
I am new to ICEM and have a question which may be easy but I cant get it to work.
I am sweeping or extruding the surface mesh along a curve, it sweeps fine but it is not aligned properly.
If I turn on the orient axially option it twists the mesh.
Am I missing something here?
Thanks
Far August 1, 2012 04:34
are you extruding mesh along curve or blocking along curve? I
clocter August 1, 2012 06:09
I did a 2D planar blocking, loaded the mesh and started to extrude it along the straight line and got stuck at the curve. Reducing the tolerance in the setting did help a little but it still does not line up.
I guess I could do a 3D blocking but this should be easy and done many times?
Thanks
Far August 1, 2012 08:55
1 Attachment(s)
would this work for you ?
http://img21.imageshack.us/img21/5411/85182369.png
http://img338.imageshack.us/img338/7906/51416416.png
http://img684.imageshack.us/img684/4638/26253661.png
http://img837.imageshack.us/img837/9403/69629490.png
http://img805.imageshack.us/img805/6461/76067471.png
