-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Export Mesh To Ansys_Error message (http://www.cfd-online.com/Forums/ansys-meshing/105589-export-mesh-ansys_error-message.html)
Zelle August 3, 2012 04:29
Hi all,
I try to export a certain mesh for use in ANSYS Fluent but I always get the error message "An internal error has occured: invalid command name "aie_ansys_file" ".
Could anybody help?
Thanks in advance and regards,
Zelle
Anne Lincke April 22, 2013 08:09
I have the same issue, have you found a solution for this problem?
jrags February 25, 2014 07:00
Hi there
I have the same problem - did you two find a sulution to this problem yet?
hardikramani November 12, 2014 02:20
The mesh is not directly export by export mesh option.
For that first of all you have to select output tab and select output solver as Fluent and then u can write mesh file as output.
