[ANSYS Meshing] windturbine meshing
Like Tree3Likes
  • 2 Post By PSYMN
  • 1 Post By PSYMN
Old   September 11, 2012, 19:40
Default windturbine meshing
James Hetfield is on a distinguished road
Hello
I want to generate a mesh around the rotor+tower of a windturbine
so I need a rotating mesh inside a stationary one
can anyone help me with it? is it good to use ICEM or I should use Ansys Meshing?
Id appreciate any kind of information
thanks
James Hetfield is offline   Reply With Quote
Old   September 12, 2012, 07:11
Paulo
strobel is on a distinguished road
i don't have good experience with it, but i guess you set that mesh is stationary or Rotating only in cfx-Pre.
strobel is offline   Reply With Quote
Old   September 12, 2012, 09:09
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Right, you could use either product...
If you are new and don't mind a tetra/prism mesh, ANSYS Meshing will be easier.
If you want a fancy Hexa mesh, then you will need to learn ICEM CFD.
In either case, you need to create an interface geometry in the shape of a cylinder aligned with the axis of rotation and extending some distance beyond the rotors.
You will end up meshing these as two pieces (the don't need to be node for node conformal, but the mesh at the interface should be roughly the same size and volume. The two meshes can be generated during the same session or separate sessions. (In ANSYS Meshing you would just have two parts and mesh them at once).
When you get to CFX or FLuent, they would be 2 separate zones. You would apply rotation to one of the zones in the solver.
James Hetfield and kemin like this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 18, 2012, 22:51
Hello
thanks for the replies
Simon, There is a problem when I want to mesh these two separate zones
I think it is related to the geometry and the way I define the rotating geometry inside the stationary one
the rotating zone belongs also to the stationary zone. I mean this region belongs to 2 different bodies
Old   September 19, 2012, 11:37
PSYMN's Avatar
Simon Pereira
You mean it is overlapping/intersecting?
You need to subtract the inner volume from the outer volume using your cad tool. If you created it in DM, then you could use "Create => Boolean" or you could try "Tools => Enclosure".
Search the online help or tutorials for info on how to use these correctly.
Simon
Old   September 19, 2012, 11:55
Simon
I did try Boolean>Subtract, but afterward I would lose the rotating zone (inner region) and there would be no zones in FLUENT to rotate
Old   September 19, 2012, 12:11
PSYMN's Avatar
Simon Pereira
Yea, look it up in the help... There is some control you need to set, something like "preserve tool body?" Yes.
James Hetfield likes this.
Old   September 19, 2012, 12:53
thanks Simon
really appreciate your replies
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
