[ICEM] Some hints required on blocking geometry |
August 15, 2012, 02:06 |
Rep Power: 13 |
Previously I learned about the blocking topology of swept wing from Far and no now I have to learn about the blocking of F6 Wing with fuselage. I now the same blocking topology will work fine for this case but I am confused how O-grid or C-grid will be inserted in this case. Some tips and advices required on how to insert C-grid and where to make splits in the C-grid for good blocking. I am attaching the .prj file with the post. Thanks in advance.
Regards |
August 15, 2012, 14:14 |
Rep Power: 20 |
.tin size was of large size that's why I only attached .prj file but what's the point? If you open project file into ICEM it just behave like .tin file after opening so that you can make any changes to it isn't it?
August 15, 2012, 15:15 |
Stuart
Rep Power: 25 |
If you go to the ANSYS Customer Portal there is a PDF file in the tutorials section for version 11, in it is a tutorial for blocking an aircraft similar to the F6. That might help you.
August 15, 2012, 15:53 |
Are you air_engineer_arsenal Admin plz don't allow double accounts from same IP
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) | Touré | ANSYS Meshing & Geometry | 2 | August 5, 2012 17:27 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 04:25 |
[ICEM] Best way to import geometry ICEM | Cottbus | ANSYS Meshing & Geometry | 4 | June 12, 2012 09:42 |
[ICEM] Cylinder Geometry and Blocking | Leepox | ANSYS Meshing & Geometry | 2 | November 21, 2011 10:32 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
