September 4, 2012, 14:49 |
3d elbow
MOHSEN HAMED
Rep Power: 14 |
i make my model in gambit is elbow with length 1 meter with more angles between inlet and outlet
each angle is a model i do for 90 , 45, 120,30 it is a circular pipe can any one help me in make this model |
September 5, 2012, 01:32 |
Maxime Perelli
Rep Power: 41 |
can you post a sketch?
In memory of my friend Hervé: CFD engineer & freerider |
September 5, 2012, 07:33 |
MOHSEN HAMED
Rep Power: 14 |
I want to create a 3d elbow geometries of angle 90, 60, 45 in gambit
seketch ihttp://www.mediafire.com/view/?4n7e16ig2m1b2qts attached |
September 5, 2012, 08:17 |
Maxime Perelli
Rep Power: 41 |
it should help you:
http://www.cfd-online.com/Forums/ans...nd-angles.html
September 5, 2012, 08:55 |
#5 | |
MOHSEN HAMED
Rep Power: 14 |
September 5, 2012, 09:22 |
Maxime Perelli
Rep Power: 41 |
create your section (surface), then sweep it along an edge (or edge-chain)
September 5, 2012, 09:27 |
MOHSEN HAMED
Rep Power: 14 |
September 5, 2012, 09:31 |
Maxime Perelli
Rep Power: 41 |
on the picture links you see what you need: your surface and the curve which will be used to sweep your section.
So first create you section Then create the curves Finally sweep surface with curve
[DesignModeler] Parametric elbow pipe | thaenan | ANSYS Meshing & Geometry | 0 | May 18, 2012 16:26 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
Appropriate model for turbulent, steady state pipe elbow flow | milos | OpenFOAM Running, Solving & CFD | 4 | July 9, 2009 02:24 |
rectangular elbow air duct problem | tony | FLUENT | 2 | August 20, 2006 19:07 |
problem of elbow pressure drop | Tony | FLUENT | 2 | July 17, 2006 17:03 |
