Modelling of Heat transfer
Hey everyone,
I need some help in modelling a system, where water flows through a Cu-pipe and heat is transfered through the walls of the pipe into a surrounding material. Which modell shall i take for this? Thermal-transient? And how can I make the geometry so that Ansys knows what's which material? Also, I dont know how to combine a mass flow (water) with the heat transfer. Help much appreciated...:rolleyes: Greetings Turtle |
please adress you problem in the fluent section. when you have walls, you can set their thickness and their materials in ansys...
Dear Ali
I have a problem in gambit i define porous_jump, then in fluent it sent an error message: Error: Cannot change po to porous-jump because there is only one adjacent cell thread. i have tried modify in gambit and its still futile. can you please guide me? Thanks zaynah |
I don't have gambit installed... i never used. i wish i can help.
Dear Ali
Its okay... Zaynah |
meshing problem
Hi every One!
i want to know that in ansys how i create thick mesh near the boundries(in 2d nozzle) and in the centre it should be thin plz help any one plzz |
