-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Script command for "select all"? (http://www.cfd-online.com/Forums/ansys-meshing/106506-script-command-select-all.html)
macfly August 30, 2012 13:56
Dear modelers,
Is there a script command in order to select all entities of a given family? e.g., select all points, select all lines, select all surfaces, etc.
Example : I would like to select all visible curves in order to create a new part containing all the curves.
I sweep tons of 2D sufaces in order to create my 3D geometry, therefore I lose track of the vertex names, curves names, surfaces names, etc. After my geometry is done, I want to clean my model and automatically create separate parts containing all vertex, all curves, all surfaces, etc.
Regards,
François
stuart23 September 2, 2012 11:37
Hi Françoi,
Try the following:
ic_geo_set_family curve partname all
You can change "curve" to "surface" if you want to put all the surfaces in a part. Also replace "partname" with the name of the part you want to move things to.
Good Luck
Stu
macfly September 2, 2012 20:29
Thanks Stuart, in Icem CFD 14.0 the following commands create 3 separate parts with points, curves and surfaces:
ic_geo_set_family point POINTS all rename
ic_geo_set_family curve CURVES all rename
ic_geo_set_family surface SURFACES all rename
Regards
François
stuart23 September 2, 2012 20:56
François, you are correct. I had forgotten to add "rename" to the end
