-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] How to deal with the added faces produced in ANSYS ICEM CFD mesh? (http://www.cfd-online.com/Forums/ansys-meshing/106520-how-deal-added-faces-produced-ansys-icem-cfd-mesh.html)
rockzh August 30, 2012 21:03
After the volume mesh is produced by ICEM CFD,there are many "added faces" produced by the code in "Mesh--Subsets".
how to deal with the "added faces" ?and are there any problems with these added faces in the CFX caculation?
Thanks for your answer!!
Far August 31, 2012 01:27
there should'nt be added faces as I know. And it is a problem.
mjgraf August 31, 2012 20:56
these really are not "added" faces but the subset acts as a container for the particular problem faces that were generated. These typically do highlight a problem with the mesh.
rockzh September 2, 2012 20:41
What is the reason for this problem?It comes from the mesh size setting or geometry?
After i do "Topology" for the geom,there is no error exited.
Chong070940103 October 17, 2014 14:48
Hi rockzh,
I think it's not caused by geom, because geom has it's own subset. It's may caused by the local size you set to generate the volume mesh. I meet with the same problem, and want to figure out how these faces generated.
