[GAMBIT] Why does my .msh file work on FLUENT but can't be imported into GAMBIT?
Old   September 7, 2012, 15:04
Default Why does my .msh file work on FLUENT but can't be imported into GAMBIT?
Paul
pmdelgado2 is on a distinguished road
I have a .msh file that reads perfectly fine on FLUENT. The same file can't seem to be imported into GAMBIT. GAMBIT gives an error:
Process completed with Error code 256.
On the command prompt, the following messages appears:
Warning: Degenerate line element ####:node0==node1 (0).
The #### indicates THOUSANDS of different line element numbers, ranging at least up to line element 3586496.
I created the mesh file using "ScanIP", which has an option to generate a FLUENT .msh file. I presume that the same file should be able to be created in GAMBIT... What's going on here? Is there something that I'm missing? How can I fix it?
pmdelgado2 is offline   Reply With Quote
Old   September 10, 2012, 08:29
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You can try to import the cas file into gambit.
Daniele
ghost82 is offline   Reply With Quote
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[ANSYS Meshing] Export .msh file for fluent by script Mostapha ANSYS Meshing & Geometry 1 August 2, 2011 05:33
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
