-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [GAMBIT] internal 2D wall in 3D model? (http://www.cfd-online.com/Forums/ansys-meshing/106833-internal-2d-wall-3d-model.html)
ghost82 September 10, 2012 10:56
1 Attachment(s)
I'm trying to simulate a double helical impeller: is it possibile to have 2D internal wall inside a 3D model?Or Do I have to assign a thickness?
I assigned the impeller faces as wall, but these are eliminated into fluent as they are "unreferenced".
See attached picture.
Thank you
Daniele
-mAx- September 11, 2012 00:52
I think you forgot to split your volume with the helicoidal surface.
Just try to move (not copy) the blue surface with any translation-vector. If you succeed then, the surface doesn't belong to the volume. And this is what gambit (fluent) expects.
So split the volume with the surface
ghost82 September 11, 2012 03:25
Thank you very much Max, it worked :)
Daniele
