Home > Forums > ANSYS Meshing & Geometry
[ICEM] Auto-Create Periodic Vertices [How to]
Old   September 10, 2012, 13:43
Default Auto-Create Periodic Vertices [How to]
minger is on a distinguished road
Has anyone gotten auto-create periodic vertices to work in ICEM? I'm specifically speaking of v14 -- I can't recall it this option was available in previous versions. There is no help documentation for this feature and am currently looking at a blocking topology where it would be SUPER useful.
minger is offline   Reply With Quote
Old   September 11, 2012, 09:31
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
this is the help that should have been in the doc...
"Auto Create" option creates periodic links between block vertices on the periodic boundaries automatically. This works on a 3D Blocking with model periodicity defined. It finds the periodic twins through Geometry transformation and blocking edge connectivity. Periodic vertices that are associated to points are found directly by geometry transformation. It expects that periodic points are with in a geometric tolerance of 1.0e-05. Periodic vertices that are projected to curves are found through periodic curve pairs or blocking edge connectivity along the periodic direction. Surface associated vertices are first found by transformation or best closest match.
Perhaps it is not working for you because your verts are not in the right locations (beyond the tolerance), or perhaps there is some issue with verts on one side having an association conflict...? Do you get an error message?
It works for me and I tried it a bunch of different ways.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 11, 2012, 12:38
I mean, are any of these requirements (tolerance, associations) documented anywhere? The only error meshing I get is "auto create periodics failed".
Old   September 11, 2012, 13:50
PSYMN's Avatar
Simon Pereira
No, I think it was a new Beta feature at 14.0... It was not supposed to be released, but something went wrong with the beta flag that was supposed to hide it.
Since it was not release, we didn't do all the normal QA, DOC, etc.
If it is not working for you, I suggest using the "create" option to create the pairs manually.
Best regards,
Simon
Thread Tools
Trackbacks are On
Internal walls of zero thickness anger OpenFOAM Native Meshers: blockMesh 22 December 15, 2015 03:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
Does blockMesh create mesh vertices in any particular order brooksmoses OpenFOAM Native Meshers: blockMesh 3 December 12, 2005 21:26
Meshing a Sphere Ajay FLUENT 9 March 29, 2004 09:14
