Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] ERROR #001100279 Real stack exceeds the maximum supported by the flow solver
Old   September 11, 2012, 07:15
Default ERROR #001100279 Real stack exceeds the maximum supported by the flow solver
peterputer is on a distinguished road
if i run my simulation i get the following error msg. It says that the Real stack exceeds the maximum supported by the flow solver. But as far as I can see the current Kwords are 4421404.5 which is much smaller than the allowed maximum of 2,147,483,647. Anyone can explain me why this error msg appears?
Regards
| Memory Allocated for Run (Actual usage may be less) |
Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node
Real 4421404.5 7732.24 9695.06 17271110.0 30928.97
Integer 818749.3 1431.85 1795.32 3198239.3 5727.38
Character 7706.6 13.48 16.90 7525.9 13.48
Logical 160.0 0.28 0.35 625.0 1.12
Double 2416.0 4.23 5.30 18875.2 33.80
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| The total number of words needed for the Real stack exceeds the m- |
| aximum supported by the flow solver: 2,147,483,647. The solver w- |
| ill continue with the stack size clipped to that value. |
peterputer is offline   Reply With Quote
Old   September 29, 2012, 10:35
Khayyamian
hadikhayyamian is on a distinguished road
I am actually beginner, but as I know you have 4.4 million Kwords that is 4.4 billion words which is greater than 2.1 billion threshold.
hadikhayyamian is offline   Reply With Quote
Thread Tools
Trackbacks are On
Review: Reversed flow CRT FLUENT 0 July 20, 2012 13:03
how to hook this udf shanu FLUENT 1 August 26, 2011 10:48
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
udf error Rashmi FLUENT 0 December 27, 2005 06:35
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
