windturbine meshing
Hello
I want to generate a mesh around the rotor+tower of a windturbine so I need a rotating mesh inside a stationary one can anyone help me with it? is it good to use ICEM or I should use Ansys Meshing? Id appreciate any kind of information thanks |
i don't have good experience with it, but i guess you set that mesh is stationary or Rotating only in cfx-Pre.
Right, you could use either product...
If you are new and don't mind a tetra/prism mesh, ANSYS Meshing will be easier. If you want a fancy Hexa mesh, then you will need to learn ICEM CFD. In either case, you need to create an interface geometry in the shape of a cylinder aligned with the axis of rotation and extending some distance beyond the rotors. You will end up meshing these as two pieces (the don't need to be node for node conformal, but the mesh at the interface should be roughly the same size and volume. The two meshes can be generated during the same session or separate sessions. (In ANSYS Meshing you would just have two parts and mesh them at once). When you get to CFX or FLuent, they would be 2 separate zones. You would apply rotation to one of the zones in the solver. |
Hello thanks for the replies Simon, There is a problem when I want to mesh these two separate zones I think it is related to the geometry and the way I define the rotating geometry inside the stationary one the rotating zone belongs also to the stationary zone. I mean this region belongs to 2 different bodies :( |
You mean it is overlapping/intersecting?
You need to subtract the inner volume from the outer volume using your cad tool. If you created it in DM, then you could use "Create => Boolean" or you could try "Tools => Enclosure". Search the online help or tutorials for info on how to use these correctly. Simon |
Yea, look it up in the help... There is some control you need to set, something like "preserve tool body?" Yes.
really appreciate your replies |
