September 14, 2012, 12:09 |
Wrinkled Mesh
Ralf Becker
Rep Power: 15 |
I am totally stuck with wrong face/edge associations in ICEM. I have tried to disassociate edges and faces from the geometry and reassociate the faces to the part. But whatever
I do, the mesh remains folded and wrinkled. What can I do to resolve this issue? What tools does ICEM provided to find the wrong associations? I have tried the edges associations and vertex projection type display. Thank you for the help. Kind regards, Ralf |
September 15, 2012, 21:07 |
Simon Pereira
Rep Power: 47 |
If the edge and vertex associations don't clear it up for me, I usually run some cut planes thru so I can see what is projecting to what on an element by element basis...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
September 17, 2012, 14:16 |
Ralf Becker
Rep Power: 15 |
Thank you for the hints and the offered help. Sorry, I am not allowed to post the data. But at least I got the job done.
What does the trick? I disassociated the faces in the wrong meshed part and realized that edges was assigned to the wrong (closest, but wrong) surface. To resolve this, I created an additional curve on the correct surface and assigned the edges to the new curve. Afterwards I reassigned the block faces to the closest surface. |
September 18, 2012, 08:11 |
#5 | |
Christoph
Rep Power: 17 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Meshing aifoil in ICEM | student123a | ANSYS Meshing & Geometry | 13 | December 8, 2010 10:40 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
