[ICEM] Problems with meshing in ICEM CFD
Old   September 12, 2012, 18:17
Default [ICEM] Problems with meshing in ICEM CFD
Benne is on a distinguished road
I am trying to mesh some kind of a drilling whole with ICEM CFD (have a look at the picture).
I think my blocking should be ok. I created an o-grid to get better angles... As you can see there is some problem with the pre-mesh. The elements at the surface are not generated correctly. It seem as if there is some kind of wrong association between the edges. There is another strange thing: When I generate a scan plane, I can see that the mesh looks better the closer the plane is placed to the end of the drilling whole. At the end of the drilling whole the mesh looks good!! So, the origin of the problem seems to be at the surface. I checked almost everything. Does anyone know what the problem is?
Greetz,
BENNE
Benne is offline   Reply With Quote
Old   September 16, 2012, 18:17
Jonathan is on a distinguished road
Hi Benne,
did you solve your problem? if not, upload your project files and i can have a look for you!
Jonathan is offline   Reply With Quote
Old   September 17, 2012, 03:08
Hej Jonathan,
yes I solved my problem... There were some wrong associations, that I had to fix. But thank you for your help!
icem, meshing, problem
[ANSYS Meshing] Very thin plate (0.1mm) ICEM CFD bad meshing msormania ANSYS Meshing & Geometry 1 April 30, 2012 07:45
[ANSYS Meshing] Icem cfd - hexa meshing arunkumarnd ANSYS Meshing & Geometry 9 April 12, 2012 05:47
pipe flow- meshing in ICEM CFD? Nikhil CFX 2 February 29, 2008 06:14
ICEM CFD Meshing Problems: Hexa Dominant Evan CFX 6 July 3, 2006 12:37
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
