[ICEM] Centrifugal pump
Old   September 17, 2012, 04:43
Default Centrifugal pump
Christoph
energy382 is on a distinguished road
Hi guys,
some issues about simulating a centrifugal pump. I'll start with the frozen-rotor-interface to receive a good initialization for transient simulation (sliding mesh).
I'll also regard leakage flow and side space flow (on pressure side). Impeller will be meshed with Turbogrid (big thx to far!), volute and side space with ICEM Hexa.
1. Do I first have to import turbogrid mesh into ICEM (that means, make blocking from turbogrid-mesh etc.) to merge the meshes or is it just fine to import the meshes in CFX-Pre with a GGI?!
2. To use the frozen-rotor-model, is it better to disregard leakage and side space flow (pressure side) as the model doesn't regard transient effects and secondary flows at the interface?
3. Rotational Offset: is it better to apply a domain rotation in CFX-Pre and create new solver input files each time or to use rotational offset in CFD-Post?
4. Regarding side space and leakage flow: what's the best approach?
To define rotor stator interface on the passage between impeller and side space and then connect side space mesh with volute mesh via GGI?
sorry for the extensive posting. But it's the first time I have to deal with different meshes (normally I only mesh with ICEM) and side space/leakage flow.
Hope some of you guys can give me some advice.
Greetings
energy
energy382 is offline   Reply With Quote
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 08:56
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 07:39
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
