Home > Forums > ANSYS Meshing & Geometry
[ICEM] how can mesh this geometry ?
Old   September 17, 2012, 11:34
Default how can mesh this geometry ?
ahmad
malay is on a distinguished road
Hi all , sorry for this question , i am new in ICEM ...
triangular channel in rectangulat solid , water inside the triangular channel ...
File Type: jpg 303887_269711906481402_1292251685_n.jpg (62.9 KB, 132 views)
malay is offline   Reply With Quote
Old   September 17, 2012, 11:43
Stuart Buckingham
stuart23 will become famous soon enough
Are both domains fluid? Ie the entire box minus the triangular prism is one domain and the triangular prism is a second domain?
The boxminus the triangular prism is the more interesting of the domains. There are two different topologies that spring to mind. The choice really comes down to your actual model; what surfaces are inlets/outlets/walls etc.? These will dictate the flow directions, then you can choose a mesh topology that aligns itself best with this.
The first potential topology is a simple 3D block split three times along the length, and the assosiate vertices to the corners of the triangle
The other potential topology is a C grid arond the triangular prism propogated out to the far walls. This will give you better alignment if the triangle is a source or a sink.
Stu
http://bc247.wordpress.com
stuart23 is offline   Reply With Quote
Old   September 17, 2012, 12:11
ahmad
yes the entire box minus the triangular prism is one domain( solid ) and the triangular prism is a second domain( fluid)
Old   September 17, 2012, 12:42
ahmad
thanks stuart23 for reply , can more explain ?
Old   September 17, 2012, 15:03
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
simple possible solution, four blocks
Far is offline   Reply With Quote
Old   September 17, 2012, 21:04
ahmad
thanks Far.... I did this blocks but the mesh quality appeared poor , especially at the corner of triangular prism ...
Old   September 17, 2012, 22:47
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
that's why you need to add a Y-grid. it is the best suitable for those kinf of corners.
Take a look at the project i attached
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   September 17, 2012, 23:00
ahmad
thanks ali .... can explain to me how you take the block for tringular prism ?? i mean how to devide the geometry to 5 blocks ( one of them to triangular prism ) ......
thank you so much ..
Old   September 17, 2012, 23:07
diamondx's Avatar
Ghazlani M. Ali
take a look at this video:
http://www.youtube.com/watch?v=InyeCmEuUVM
y-grid is created, also some vertices are merged. everything you need is in this video.
time to go to sleep... see you tomorrow
Regards,
Ali
Old   September 17, 2012, 23:09
ahmad
thank you so much my bro ..... good night ...
Old   September 18, 2012, 06:13
Far
Sijal
slide the vertices of the middle downward to improve the quality. Or
1. Insert Y Block
2. Put O-grid
Old   September 18, 2012, 06:19
ahmad
1. Insert Y Block
2. Put O-grid
thanks Far ..... i get confuse when i try to make Y-block
Old   September 18, 2012, 11:39
Far
Sijal
check this Quarter O-grid from vertices and !!!!!! Why?
and Video tutorials on some ICEM basic and sphere cube
Old   September 18, 2012, 11:41
ahmad
thank you so much ...
Old   September 18, 2012, 12:03
Far
Sijal
Few snapshots for your case (you have fluid and solid regions ?)
Old   September 18, 2012, 23:18
ahmad
yes i have fluid and solid regions ....
thanks bro
Old   September 18, 2012, 23:24
ahmad
when i finish making mesh by ICEM with fluid and solid i read it by fluent , but in fluent only one zone appear ( solid ) why ???
Old   September 19, 2012, 01:06
Far
Sijal
Because you don't have the fluid region!!!
Right click on the parts then choose the last option (blocks). Rename to fluid and select the fluid blocks (blocks in Y-grid). Recreate premesh and convert to mesh. After that export the mesh and import into Fluent. You are done.
Old   September 19, 2012, 01:17
ahmad
really i thank you so much ..... i get it
Old   September 19, 2012, 02:20
Far
Sijal
When you have the triangular prisms, dont compare their quality to hexa. With prism, quality of 0.01 is also good enough
Here I am quoting one of the Simon's post regarding quality. Low quality Tet prism mesh post # 15
If you haven't seen the inverted issue, then no worries... It happens only in 13.0 for redistribute prism, but is already fixed... In the mean time, the work around is to redistribute using the "Move => Redistribute Prisms" command. There isn't any more to tell.
Min tetra quality should probably be above 0.2, but if you have some below, it is probably fine, particularly in a non critical area. CFX is pretty robust, you could try as low as 0.05.
The Prism metric is really harsh in ICEM CFD. If you can get above 0.01, it will probably run fine in CFX... You could even go lower. (Maybe others can comment on their worst mesh that converged)...
Hexa, you are usually looking at min angle and aspect ratio... We shoot for an angle over 18, but will take anything over 9.
Thread Tools
Trackbacks are On
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Mesh a geometry without stl file eysteinn OpenFOAM Native Meshers: snappyHexMesh and Others 0 May 5, 2011 10:15
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
