[ANSYS Meshing] heat transfer through a pipe
Old   September 14, 2012, 16:32
Default heat transfer through a pipe
Dhaval Shiyani
cfdjunkie is on a distinguished road
Hi everyone,
I am new to using ANSYS and flow simulations. I have a problem which I am working on. It is flow through two pipes with a block placed on the top of the innner pipe with a temperature of 1000K and the heat transfer coefficients for all the surfaces are know. I have to simulate to find out the temperature on the inner surface of the outer pipe (The velocity of the flow is not known). I created a geometry in SOLIDWORKS and meshed it in ICEM CFD (I have attached the picture of the solid model I am talking about). Now I was trying to use Fluent to simulate the flow but I don't know if I can give specific temperatures to blocks and surfaces. Please bear with me and help me out. If you can tell me which software would be the best for this problem and how to give specific properties to blocks and walls after meshing, it would be great.
Please reply as soon as you can.
Thanks in advance.
cfdjunkie is offline   Reply With Quote
Old   September 15, 2012, 21:16
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
All the surface temperatures are setup in the solver (but part names are setup in the mesher).
The only tricky part is you need to remember to setup the Energy equation... Go to "Solution Setup => Models" and turn on the "Energy" equation.
Then to apply a temperature to a particular surface, go into Solution Setup => Boundary Conditions. Select the boundary you want (you would have named the parts in ICEM CFD before generating the mesh so it is easy to select them here) and choose "edit". Under edit, there are tabs, go to the Thermal Tab to set up the temps...
You can do the same for zones, but you need to turn on the "Fixed Values" option so you can set the temp.
If you can't find it, just try a fluent CHT (conjugate heat transfer) tutorial and you should be all set.
Best regards,
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   September 18, 2012, 21:35
Dhaval Shiyani
Thanks for replying. I did exactly as you said but now it shows an error which reads something like "Divergence detected in AMG: pressure correction". Also I cannot seem to find the conjugate heat transfer tutorial you were talking about. If you could please reply me the link for the tutorial for both ICEM CFD and Fluent, it would be a great help.
Thank you again.
Old   September 18, 2012, 21:53
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
that error can mean a lot, probably bad setting of boundary condition ?...
if you adress your problem in the fluent section of cfd-online you might get more help than here.
Cornell university has very good cfd modules to start, some include heat transfer and convection.
fluent's tutorial are available through ansys's website in the customer portal. if you don"t have an account you can register, you just need your customer number, the way i get is by starting icem cfd...
or you can google "tutorial fluent heat transfer" i'm sure you'll find something...
Good luck
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 17, 2014 23:45
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 04:07
heat transfer along a pipe lysander FLUENT 0 July 27, 2012 23:39
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
