[ANSYS Meshing] Mesh Quality
Like Tree4Likes
  • 2 Post By Far
  • 1 Post By Far
  • 1 Post By Far
Old   September 18, 2012, 02:55
Default Mesh Quality
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
What are the parameters used to test the mesh quality:
I know a few such as aspect ration, expansion ratio, orthogonality angle.
There is also this parameter CGI, kindly explain it.
Add any other parameters that are important when reporting a mesh.
Thank you
Regards
Hamed
hamed.majeed is offline   Reply With Quote
Old   September 18, 2012, 10:01
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
topic about mesh quality is discussed multiple time in this forum try searching the forum i'm sure you will find a lot.
Don't know much about cgi parameters, hope someone else can explain it.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   September 18, 2012, 11:12
Far
Sijal
Originally Posted by hamed.majeed View Post
Thank you
Regards
Hamed
mostly we are interested in min angle (>18 deg) , minimum quality (shoud be > 0.3) and expansion ratio. Mostly these parameters are viewed from solver point of view.
There is very nice explanation of these parameters by Simon on this forum, search is the key
hamed.majeed and metmet like this.
Old   September 18, 2012, 14:18
Talking
AHMED
navedahmid is on a distinguished road
I think its GCI not CGI
navedahmid is offline   Reply With Quote
Old   September 19, 2012, 11:17
PSYMN's Avatar
Simon Pereira
The Help documentation should also include something for each metric, but I am not sure what metric you are asking about (GCI or CGI, I don't know of either). What tool are you looking in?
CFD Online Users Survey
Old   September 21, 2012, 22:23
Hamed Abdul Majeed
It is the grid convergence index GCI. It is a factor to estimate discretization error based on Richardson extrapolation principle
Old   September 22, 2012, 02:09
Far
Sijal
Hi
Well it is the index of quality of CFD which you are performing. In other words, it is you who will decide that how much mesh size is needed to the asymptomatic behaviour. Whether it is 1 million, 10 million or even 100 million. ICEM will give you whatever you ask for.
hamed.majeed likes this.
Old   September 22, 2012, 10:35
Hamed Abdul Majeed
thnx for reply.
I have another question. We place the 1st node from the wall based on y+ value and the formula 1st node distance is
delta y = sqrt(74)*Re^(-13/14)*L*y+*L
The value of y+ in above formula depends on the turbulence model used.
My question is:
Once 1st node distance is specified using above formula, what are the parameters that govern the selection of expansion ratio applied to the mesh.
I mean what should the increasing gap of node be starting from the 1st node
Old   September 22, 2012, 11:40
PSYMN's Avatar
Simon Pereira
Usually a ratio of 1.2 is used. But you could go higher or lower if you want the total height of your boundary layer to be less or greater.
The point is just to have enough mesh discretization to capture the boundary layer profile. That profile is changing faster near the wall and reduces as you move away. The ratio is just to reduce the number of nodes so you are not using the same resolution to capture less change.
Old   September 22, 2012, 16:25
Far
Sijal
thnx for reply.
My question is:
Rule(s) of thumb:
1. Use expansion ratio 1.2 at max and for transition critical flows lower values to 1.15 or 1.1
2. For fully turbulent flows you can use the Y+ upto 10, in that case you will have the 10-15 nodes in the whole boundary layer. You can find the boundary layer total thickness from the turbulent flat plate boundary layer formulae
3. Boundary layer gets thinner as Reynolds number increases and vice-versa
PSYMN likes this.
Old   September 23, 2012, 02:35
cfd seeker is on a distinguished road
Aaah I wish the whole world would have like that but the transitional flows always give me a headache and as a result extra care for wall y+ and no. of cells in boundary layer
I want to add something here, after finding boundary layer thickness from turbulent flat plate boundary layer formula, reduce it by an order of magnitude to get good approximate for airfoils/wing problems
cfd seeker is offline   Reply With Quote
Old   September 23, 2012, 02:48
Far
Sijal
Originally Posted by cfd seeker View Post
Aaah I wish the whole world would have like that but the transitional flows always give me a headache and as a result extra care for wall y+ and no. of cells in boundary layer .
For transitional flows (laminar to turbulent), you need Y+ less than 1 with other constraints.
Old   September 23, 2012, 02:55
Yes and the most important constraint is values of "Turbulence Parameters"
Old   September 23, 2012, 02:56
Far
Sijal
I meant the mesh constraints like enough no of nodes in normal and streamwise direction.
Old   September 23, 2012, 03:06
Turbulence parameters also affects the performance of Turbulent Transitional Models
mesh, mesh quality
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Polyhedral Mesh Quality in Star-CCM+ niazaliahmed STAR-CCM+ 3 March 8, 2012 13:51
[ICEM] Tetra mesh quality before and after prism layer Chander ANSYS Meshing & Geometry 0 December 25, 2011 22:04
