-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Mesh export with mid side nodes (http://www.cfd-online.com/Forums/ansys-meshing/107184-mesh-export-mid-side-nodes.html)
SGA September 19, 2012 15:43
I am trying to export a mesh in .msh format and read it in my own code.
My code uses properties of quadratic tet elements. When I try to export the mesh using mid side nodes, I still get the linear elements in output mesh file. Is there any way I can export mesh with all the mid side nodes ?
PSYMN September 20, 2012 08:39
The fluent msh format is a linear mesh format. If you want quadratic mesh, you should export in a FEA format such as ANSYS or Nastran. These formats support quadratic mesh.
SGA September 20, 2012 11:39
Thanks. But I don't know how to do that. All the options I see for exporting are,
FLUENT, POLYFLOW, CGNS, and ICEM CFD.
PSYMN September 20, 2012 14:24
Do you have access to ICEM CFD? If so, choose that format. THen load the mesh in ICEM CFD and you can export to about 100 other formats.
It may be that the FEA options in ANSYS Meshing are hidden some how by your physics setting or something like that... Not sure.
SGA September 21, 2012 00:04
Okay, Thanks. I used FE Modeler in workbench to save it in Ansys mesh format.
Now I can see all the nodes in the mesh file.
