Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] How to convert a grid node to a vertex?
Old   October 11, 2012, 12:42
Question How to convert a grid node to a vertex?
Mosi Owa
BMCombustor is on a distinguished road
Hi
I have a complex geometry which has been generated by stereolithography (STL file). The thing is that the whole geometry is just one surface while I need to define some parts as inlet and outlet. What I have in my mind is to put some vertices on those related faces of my interest and create a plane (or face) and then move on toward the rest of it; but the problem is that I don't know the right coordination to put the vertices. I have meshed my surface and am sure that my face of interest (shown with a green circle and arrow in the attached image) is completely planar and I could tangent a surface on it but I do not know how! Does anyone have an idea?
Thanks
BMCombustor is offline   Reply With Quote
Old   October 12, 2012, 00:59
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
the question is: is your volume virtual or real?
Because the handling may be quite laborious with virtual, but you can try this:
If you want to add your circle as imprinted circle on your surface mesh, then create your circle away (and normal) to your surface, and finally try to project your circle on your surface by enabling split option, and giving the right vector (that's why I mentionned "normal" earlier).
http://aerojet.engr.ucdavis.edu/gamb...create_project
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 12, 2012, 14:04
Mosi Owa
I gave it a try but it didn't work! It reflects an error saying: "Cannot project at the given location because the rsult would be a degenerate edge." FYI, my volume is a virtual one because I couldn't make it with real option. (First I had just a closed surface and then I split it into two arbitrary surfaces using a rectangle; then I created a virtual volume using those two surfaces. Selecting "real" didn't work!).
Thanks
Old   October 15, 2012, 01:30
-mAx-'s Avatar
Maxime Perelli
Can you provide me your dbs file?
Old   October 15, 2012, 14:06
Mosi Owa
Sure; can you give me your email address?
Old   October 24, 2012, 06:59
-mAx-'s Avatar
Maxime Perelli
edge projection doesn't work properly and you can do something by projecting parts of edges (circle).
Maybe you need to work on the stl file with a cad package and then reimport in Gambit
Old   October 25, 2012, 11:00
Mosi Owa
Attachment 16361
Attachment 16362
Thank you mAx. I will try in CAD to see what happens.
Thread Tools
Trackbacks are On
Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Mesh Utilities 41 January 17, 2013 03:43
convert a structured multiblock grid to an one unstructured: modification of cells Mirage ANSYS 0 July 18, 2012 09:14
[ICEM] convert a structured multiblock grid to an one unstructured Mirage ANSYS Meshing & Geometry 4 July 11, 2012 10:36
CGNS - convert BC from node to face Charles Main CFD Forum 1 November 1, 2008 09:50
How to convert cgns filr in node array? John FLUENT 0 November 12, 2006 23:54
