Home > Forums > ANSYS Meshing & Geometry
[ICEM] geometry repair
Old   October 12, 2012, 13:04
Default geometry repair
Rong Yue
yuhehuan is on a distinguished road
Hi! I have a problem of my geometry. I attached a picture. Have you found some holes of in this surface? Does it affect the mesh quality? How could i deal with it? Thanks!
yuhehuan is offline   Reply With Quote
Old   October 12, 2012, 14:16
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
ICEM is very much tolerant of small problems in the geometry. Give it a try and come here back.
Far is offline   Reply With Quote
Old   October 12, 2012, 14:26
Rong Yue
But I can't generate prim mesh. And the mesh quality is only 0.4.
Old   October 12, 2012, 15:12
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
0.4 is ok for fluent !! give it a try...
Regards,
New to ICEM CFD, try this document --> http://goo.gl/G2gkE
Ali
diamondx is offline   Reply With Quote
Old   October 12, 2012, 15:24
Rong Yue
But when i import the mesh into fluent, the convergence curve is bad, like this picture.So I think it's the problem of the mesh. I am not sure where the problem it is.
Old   October 12, 2012, 18:47
diamondx's Avatar
Ghazlani M. Ali
i think it's more because of your geometry than your mesh.
You outlet is way too close to your inlet... what are you trying to model ??
Regards,
Ali
Old   October 12, 2012, 23:48
Smile
Rong Yue
Oh, maybe. I want to analyse the pressure drop of air flow through the widest path unit (it's made of four grain kernels). So I can't change the model. I am not sure if i use the structed mesh the mesh quality will change. Because I guess the Y-GRID may be better. So do you have some idea how to use structed mesh on my model? Thank you so much!
Old   October 13, 2012, 03:25
Far
Sijal
Blocking can be done. You can refer to this thread, where discussion on blocking is under way.
Old   October 13, 2012, 17:30
Rong Yue
Thank you so much for your help! I will read it then think about how i can do.
Old   October 14, 2012, 01:52
Rong Yue
Hi, I used Y-grid to my geometry. But there is a problem of my mesh. I am not sure if it is the problem of block or the surface of the geometry. I think there is no problem of my block. Could you check it for me? Many thanks!
Old   October 14, 2012, 01:53
Far
Sijal
The only way to learn ICEM is to share the .tin file
Old   October 14, 2012, 02:00
Rong Yue
thanks a lot!
Old   October 14, 2012, 02:11
Far
Sijal
oh, complex model. Trying my best and will comeup with solution very soon.
Old   October 14, 2012, 02:20
Rong Yue
it is really complex. I have been confused with it for a month. I tried unstructed mesh but the the convergence is not good in fluent. So I am trying to use structed mesh now. Hope you can sovle it. And I will keep trying. Thank you so much for your help!
Old   October 14, 2012, 02:23
Far
Sijal
The prisms in boundary layer and tetra in the rest of the domain is good choice for this model. And convergence should be good with refined boundary layer. It is some sort of intake?
Old   October 14, 2012, 02:32
Rong Yue
Sorry, I just started learning ICEM and don't know how to use different meshes for different areas. This is a model for airflow. The inlet is at the bottom surface. And the outlet is one of the side surfaces of this model. Somebody said that the convergence is bad becuase the inlet is too close with the outlet. I am not sure. I think i can't change the model. So, just improve the mesh quality.
Old   October 14, 2012, 02:35
Far
Sijal
You can extend the inlet and outlet domain and apply slip BOCO on them and record the data at the original inlet and outlet planes.
Old   October 14, 2012, 02:42
Rong Yue
Sorry, i really don't have an idea about your advice. I am a newcomer. I think if the structed mesh can't change the convergence, then I will try another method. So, firsly, try the structed mesh,maybe it will work.
Old   October 14, 2012, 02:44
Far
Sijal
I am also sending you the link of training material through pm
Old   October 14, 2012, 02:49
Rong Yue
Thank you so much for your tutorial! You are really so nice!
Thread Tools
Trackbacks are On
[GAMBIT] Geometry repair doodek ANSYS Meshing & Geometry 5 February 10, 2011 15:42
ICEM --- question about repair geometry zhaohui ANSYS Meshing & Geometry 1 April 21, 2010 18:54
repair the geometry in the ANSYS-ICEM feixiangniao ANSYS Meshing & Geometry 3 March 31, 2010 05:53
how to repair geometry by another way Priscila CFX 4 August 2, 2007 11:43
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
