-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [Other] Turbo grid Splitter meshing (http://www.cfd-online.com/Forums/ansys-meshing/108196-turbo-grid-splitter-meshing.html)
vitulaaak October 17, 2012 03:28
does anyone have an experience with meshing radial splitter blade wheels using ATM Optimized topology?
I use this topology for full blade wheels and it works really well. When I tried to use it for splitters, it always falls on errors, that it cannot choose the topology automatically.
Thank you
Vit
Far October 17, 2012 04:32
ATM is working fine for splitter blade. Either you you have problems in the geometry files (profile.curve etc) or you are using Turbogrid V13
http://imageshack.us/a/img254/4017/85915508.png
vitulaaak October 17, 2012 06:41
I checked the BGD output and there seemed to be no problem.
Yet using the ATm is not working. I am using workbech 14.
V.
Far October 17, 2012 06:42
is it possible for you to send the .curve files on forum or through pm?
Far October 17, 2012 07:02
Trailing edge shape is round or square? if sharp then check the option of cut-off or square trailing edge option for the both blades (main and splitter)
http://imageshack.us/a/img203/1528/73088892.png
vitulaaak October 17, 2012 08:31
Hi Far,
I think, I will not be able to share the files unfortunately.
I am using for both full bl and splitters ellipse 2:1.
Also trailing edge is rounded.
V.
