Home > Forums > ANSYS Meshing & Geometry
[ICEM] 45 cylinder
Like Tree1Likes
  • 1 Post By nitinbansal184
Old   October 17, 2012, 04:47
Default 45 cylinder
FVH
FVH is on a distinguished road
I'm new to icem maybe someone can give me a little help.
I try to mesh (hexa) a diagonal cylinder. I used blocking and rotated the block within which the the cylinder is 45 degrees. That block is a OGrid and i associated the edges from the OGrid to the cylinders curves(pictures).
The problem is if i read that mesh in Fluent (after translation in icem etc.) the cylinder is missing.
Maybe someone knows how to handle tis problem or a better way to mesh the cylnider
thx
FVH is offline   Reply With Quote
Old   October 17, 2012, 05:08
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
can you attach the .tin?
Far is offline   Reply With Quote
Old   October 17, 2012, 05:57
FVH
Hi Far,
I already tried different blockin strategys but couldn't find a godd way to mesh the cylinder.
thanx for your help
Old   October 17, 2012, 06:08
Far
Sijal
are you trying the simulate the tip effects as well, or just 3d cylinder due to nature of flow?
Old   October 17, 2012, 06:26
FVH
I'm trying to simulate heat transfer and CW
Old   October 17, 2012, 08:30
FVH
also tip effects
Old   October 18, 2012, 01:03
nitin bansal
nitinbansal184 is on a distinguished road
thx
Hi Far,
thanx for your help
Meshing done,just attaching blocking file so you can idea about splitting and association.
Sory for quality have "less time" reached min ortho 0.7. rest you must do it yourself
Far likes this.
nitinbansal184 is offline   Reply With Quote
Old   October 18, 2012, 02:54
Far
Sijal
Fantastic. I have improved some angle issues in blocking, but it is less than .00000001 % effort, originally put by nitinbansal184
Old   October 18, 2012, 12:36
cfd seeker is on a distinguished road
Really great but how you have done the inclined cut in the vicinity of inclined cylinder(this has made the job simple for you)?
cfd seeker is offline   Reply With Quote
Old   October 19, 2012, 00:26
nitin bansal
Recently i have done meshing on flat plate with angle of attack 15 vertically and tilted at some angle horizontally.......Used same concept here..
Old   October 19, 2012, 01:41
If I am not getting you wrong you mean to say that you have done the blocking of cylinder in vertical position and then tilted the blocking at the angle, is it so?
Old   October 21, 2012, 11:20
FVH
Thank you all very much for your answers!
I will be back on the PC on monday but probably i will have some more questions, if you don't mind!
Old   October 22, 2012, 04:58
FVH
Hi Nitinbansal and Far,
thank you very much it is really ineterssting how you approach this problem. Can you give me any advise how i should use blocking in the future? I know that it always depends on the current problem but mybe you have some basic advises.
Old   October 22, 2012, 09:08
Far
Sijal
Understand how to use the o-gird function
Thread Tools
Trackbacks are On
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
