Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Fluid-Fluid interface and Perioidic
Old   October 17, 2012, 21:51
Red face Fluid-Fluid interface and Perioidic
mohamed khedr emam
m5edr is on a distinguished road
Hi All
I'm facing the following situation in my wind turbine project:
in fluid-fluid interface,Fluent refused to accept the periodic B.C
I tried ICEM and Ansys Meshing and found the same results
Again fluid-fluid interface should be two faces of "interface" not single "Interior"face while Periodic B.c of periodic faces doesn't match with interface,Mesh is complete But Fluent refused to complete
Any suggestion
Thanks in advance
m5edr is offline   Reply With Quote
Old   October 18, 2012, 07:17
Christoph
energy382 is on a distinguished road
could have many reasons. did you check "periodic problems" in icem? have you set up periodicity correct? rmb -> faces -> periodic faces -> do they look red? if not, check periodic verticies
have you tried to copy/rotate your mesh in icem? are there any overlapping elements or is it just fine?
Originally Posted by m5edr View Post
Hi All
Any suggestion
Thanks in advance
energy382 is offline   Reply With Quote
Old   October 18, 2012, 12:39
mohamed khedr emam
Thanks Christoph for replay
First, I didn't found (rmb -> faces -> periodic faces) I think you mean to do this in ICEM Blocking but I'm not using Blocking techniques.
second: the Fluid-Fluid interface if i made it (one) interior face, every thing is good and Fluent accept the mesh and periodic face But if the Fluid-Fluid interface (should be interface: one for internal fluid and one for external fluid) ICEM check Mesh show me error (check this pls Interface meshing at dual zone geometry)
If you want to see my model this is the Link http://www.4shared.com/rar/IierXH9h/Project.html
Thanks in advance
interface, wind turbine
Thread Tools
Trackbacks are On
