[GAMBIT] Rotating Circle in a parrallel plate |
October 31, 2012, 04:21 |
#41 |
Maxime Perelli
Rep Power: 41 |
see post #29
In memory of my friend Hervé: CFD engineer & freerider |
June 7, 2013, 07:50 |
#42 |
Mrinal K R
Rep Power: 14 |
In the same way of rotation of circle(by giving angular velocity to circle) is it possible to get only translational motion (by giving translational velocity to circle) of circle in the rectangle domain???
June 10, 2013, 06:59 |
#43 |
Maxime Perelli
Rep Power: 41 |
yes
but you have to modify your zones and then remesh With translation motion, you have other possibilities than sliding mesh (layering, remeshing or sliding mesh)
June 10, 2013, 08:47 |
#44 |
Mrinal K R
Rep Power: 14 |
Thank you.
Can you please explain the steps how to do? is UDF required for movement of circle?? |
June 11, 2013, 01:34 |
#45 |
Maxime Perelli
Rep Power: 41 |
you need UDF only if your motion isn't known in advance
Else you can set a constant velocity , or you can use a scheme file for setting the motion in function with time (interpolation)
June 11, 2013, 07:05 |
#46 |
Mrinal K R
Rep Power: 14 |
i want to translate circle only in certain distance??
for that what to do? can you tell what are the steps to be followed?? |
June 11, 2013, 09:23 |
#47 |
Maxime Perelli
Rep Power: 41 |
check this tutorial
http://aerojet.engr.ucdavis.edu/flue...tg/node181.htm
June 11, 2013, 12:10 |
#48 |
Mrinal K R
Rep Power: 14 |
Thank you..
Rotating plate. | farrr | CFX | 7 | July 20, 2015 14:24 |
Rotating thin cylindrical plate heating/cooling | trentar | Main CFD Forum | 0 | August 17, 2012 07:35 |
rotating plate | AlexAlex | FLUENT | 0 | October 11, 2011 12:04 |
vibration of a rotating plate in water | zhm | Main CFD Forum | 0 | March 2, 2010 18:50 |
jet on rotating plate | A.TOUZANI | Main CFD Forum | 0 | January 30, 2003 10:05 |
