[ICEM] how to improve mesh quality in the hydrocyclone |
October 23, 2012, 01:59 |
Rep Power: 13 |
Dear Sir,
I am Veerabhadra Rao and working as JRF in IITH. I got meshing problem in the hydrocyclone. I got fine mesh at the centre and coarse mesh towards the wall and the quality of the mesh is low. Can you suggest how to improve mesh quality in the hydrocyclone. |
October 23, 2012, 02:26 |
Rep Power: 13 |
Hi and welcome,
i think we need some more informations. Did you generate a hex mesh or a tetra mesh. If you worked with a tetra mesh you can use prism at the walls. If you are using hex mesh i would think that your spacing is wrong and suggest that you look at it a change it im neccesary. (You can check it under Pre-Mesh Params and then Edge Params). kind regards John |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 22:04 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
