Home > Forums > ANSYS Meshing & Geometry
[ICEM] Problem loading ICEM script
Old   October 23, 2012, 05:48
Question Problem loading ICEM script
Totize is on a distinguished road
Hello all,
I'm starting an internship on CFD simulations on a cascade airfoils 2D grid and I chose to parametrize my airfoil geometry and domain on CATIA v5 (the CAD software I master more for the moment). Thus, I want to use ICEM and its scripting functionality to save time for other simulation.
I started to test it just for loading my DWG geometry. When I check the script is well working, the geometry doesn't appears as needed.
I uploaded a 1mn video to better understand this small (I think) problem :
Thanks in advance for your help
I'm glad this forum seems to be full of ressources.
Totize is offline   Reply With Quote
Old   October 27, 2012, 10:41
Stuart Buckingham
stuart23 will become famous soon enough
You say the geometry is not as needed, is there any geometry showing up at all?
The script that you have created has the following functions:
1> Run a conversion program to convert the .dwg file to a .tin file
2> Load the .tin file.
There may be problems with saving over an old file? It is hard to know without a more detailed explanation
stuart23 is offline   Reply With Quote
Old   October 31, 2012, 09:42
Ah yes !
Thanks a lot, I tried to remove the old TIN file before to load the script, and it works like a charm now. I can see the geometry on my screen with no problem.
Maybe it was, as you said, a problem of saving over an old file.
Thanks again, have a nice day.
Thread Tools
Trackbacks are On
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 14:14
[ICEM] ICEM CFD script CFD-1987 ANSYS Meshing & Geometry 3 June 5, 2012 07:56
icem script prad CFX 5 July 23, 2010 16:30
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Problem exporting big meshes from ICEM to Fire Emil CFX 0 October 10, 2008 13:06
