[GAMBIT] Rotating Concentric Cylinder with mech density higher at the edges
Like Tree3Likes
  • 1 Post By ghost82
  • 1 Post By ghost82
  • 1 Post By ghost82
Old   October 25, 2012, 10:57
Default Rotating Concentric Cylinder with mech density higher at the edges
rshbhb
rshbhb is on a distinguished road
Dear MAX,
Hello Sir,
I want to make the kind of geometry as shown in the image (attached) in the gambit software. I believe that you can help me.
Awaiting your reply soon.
Thank you.
rshbhb is offline   Reply With Quote
Old   October 25, 2012, 12:25
ghost82's Avatar
Rick
ghost82 will become famous soon enough
1-create the external cylinder (centered in 0,0,0)
2-create the internal cylinder (centered in 0,0,0)
3-subtract the internal cylinder from the external one
4-create the plane y=0
5-split the volume with this plane
6-mesh edges of the lower base of your volume and mesh the two faces with quad map scheme (if you cannot mesh with map scheme change the vertex type to end)
7-mesh the generatrix of the cylinder
8-mesh the volume with hex cooper scheme, choosing as faces bottom and top faces
Daniele
ghost82 is offline   Reply With Quote
Old   October 25, 2012, 12:56
rshbhb
Thank you Daniele.
I'll try and inform you.
Old   October 26, 2012, 02:52
ghost82's Avatar
Rick
Originally Posted by rshbhb View Post
Thank you Daniele.
I tried the steps above, the cells of the 2 volumes if meshed with the cooper scheme will be slightly distorted;
so:
1-create the external cylinder (z positive)
2-create the internal cylinder (z positive)
4-create the plane y=0 (for example a big square in xz)
6-mesh edges of the bases of your 2 volumes and mesh the 4 faces with quad map scheme
8-mesh the 2 volumes with hex map scheme
Daniele
Old   October 26, 2012, 06:10
rshbhb
I tried this too. but the problem I am facing is, I cannot join back the two volumes after meshing.
I tried to merge the two volumes but the two faces (inside the volume of the annulus) still remain . How do I remove them?
If there is any other alternative (like, to give the BC for the interior faces as INTERIOR) then please let me know.
Thank you,
Daniele.
Old   October 26, 2012, 06:15
ghost82's Avatar
Rick
Thank you,
Daniele.
Why do you want to merge the volumes?
Internal faces are not treated as walls, and the two volumes are connected as they are a single volume!
Make sure you check "connected" when you split the volume!
rshbhb likes this.
Old   October 26, 2012, 06:26
rshbhb
Thanks again. I thought that internal faces will be counted as walls.
I want to Give boundary conditions as:
Upper faces-2faces as walls (stationary)
Lower faces-2 faces as walls (stationary)
Interior faces (rotating)
exterior faces (stationary)
& the interors volumes as FLuid (liquids)
(Basically I am trying to make a rheometer geometry)
Should I define the internal & external faces as walls too,, in GAMBIT ?
Old   October 26, 2012, 07:00
ghost82's Avatar
Rick
Should I define the internal & external faces as walls too,, in GAMBIT?
Yes, you have to define them as walls
rshbhb likes this.
Old   October 26, 2012, 07:12
rshbhb
Will I have to select any kind of dynamic or sliding mesh OR I can do normal meshing and rotate the inner walls in FLUENT solver ? (I use the 2nd option).
-Awaiting a quick reply. THanks
Old   October 26, 2012, 07:16
ghost82's Avatar
Rick
I think you can only set in fluent the inner wall as "moving"->rotational in respect to z axis as in the tutorial "Non-Newtonian Transitional Flow in an Eccentric Annulus" (search google); However, you should better open a new thread in the fluent forum to have other opinions.
Daniele
rshbhb likes this.
Old   October 26, 2012, 07:20
rshbhb
Daniele
I'll open a new thread in the FLUENT forum. But as you are aware of the problem description can you help me out with FLuent simulation too ?
Old   October 26, 2012, 07:25
ghost82's Avatar
Rick
First try to solve the problem on your own, you will learn lots of things from your mistakes; however if you will get stuck at some point me and other people will help you.
Daniele
Old   October 26, 2012, 07:34
rshbhb
Daniele
Dear Sir/ Ma'am,
I have tried to solve the problem with simple mesh geometry but the results obtained by them are a bit absurd.
I'll be uploading the images of my simulations in the new thread for my queries... I'll post the link to my thread in this thread too in few minutes...
THank you !
Old   October 26, 2012, 07:53
rshbhb
Below is the link to the new thread:
Please help.
Kind Regards,
Rishabh
http://www.cfd-online.com/Forums/flu...tml#post388662
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Strange pressure distribution with a rotating cylinder HiF OpenFOAM Running, Solving & CFD 0 July 17, 2010 00:06
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
