[ICEM] Generation of geometry and mesh automatically
Like Tree1Likes
  • 1 Post By venkat_aero2007
Old   August 2, 2013, 06:35
Default Generation of geometry and mesh automatically
Ravikiran Anapagaddi
rkiranmat is on a distinguished road
Dear All,
I would like to generate the geometry (.tin) and mesh generation (.msh) automatically using Ansys ICEM for CFD simulations using Ansys-CFX by writing any code. I mean to say that, If user gave the dimensions of the geometry, then code should generate .tin and .msh file for simulations.
Can any one help in this?
Thanks and Regards,
Ravikiran
rkiranmat is offline   Reply With Quote
Old   August 12, 2013, 08:37
Default Replay Script
venkatesh
venkat_aero2007 is on a distinguished road
You can record the commands using reply script
Before you start creating the geometry, go to File > Replay Scripts > Replay Control
have a look on this link to understand how the scripting is done
http://www.youtube.com/watch?v=tYrbScUH9RE
Are you going to do optimization? If that is the case, you can use matlab or any other programming language. If you are going to do in Matlab, you should write a function in matlab which calls the ICEM CFD and execute the replay script.
rkiranmat likes this.
venkat_aero2007 is offline   Reply With Quote
Old   August 12, 2013, 08:45
Dear Venkatesh,
Thank you for your reply. I have got the methodology of programming in ICEM. Now I am writing script for auto-mesh generation and CFD simulation.
I am writing in fortran code.
Thanks and Regards,
Ravikiran
Old   August 12, 2013, 08:53
venkatesh
Hi Ravikiran,
I have done it in Matlab. Sorry I done know how to do that in Fotran. Hope some one will give you a better suggestion.
Old   August 12, 2013, 09:02
Thanks alot. Can you please share your matlab files if you can. So that it will be useful further. Mail id: rkiranmat@gmail.com
Thanks and Regards,
Ravikiran
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
