[ANSYS Meshing] Inflation layer
Like Tree2Likes
  • 1 Post By federico.bruni
  • 1 Post By jrunsten
Old   October 26, 2012, 08:52
Default Inflation layer
Federico Bruni
federico.bruni is on a distinguished road
Hi averyone,
I have a problem with meshing a complex geometry. My case is a valve with a tilting shutter and I have to calculate equilibrium position of the shutter and also head losses.
So I have to control first layer thickness on both shutter and valve walls.
I created a named selection for shutter and one for walls, but I am not able to insert the inflation option for both.
In the general meshing setting you can only choose between 'program controlled' and 'chosen named selection'. 'program controlled' doesn't make what I want and in 'chosen named selection' you can pick only one selection but I have two.
If I insert an inflation option, it asks me for 'boundary' of the inflation layer so I pick up its edges but it doesn't work. (I'm also not sure what this boundary means).
Have you got an idea about how to solve this problem?
Thank you
rgd likes this.
federico.bruni is offline   Reply With Quote
Old   October 28, 2012, 23:30
nitin bansal
nitinbansal184 is on a distinguished road
Originally Posted by federico.bruni View Post
Hi averyone,
Thank you
Can you share some geometry..will try it
nitinbansal184 is offline   Reply With Quote
Old   October 29, 2012, 08:25
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Using "program controlled" should generate inflation on all surfaces that are NOT in a named selection.
By inserting inflations instead, unless it's a swept mesh, the boundary should be chosen as the surfaces that make up the wall and not the edges
rgd likes this.
jrunsten is offline   Reply With Quote
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 03:22
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
2d axysymmetric inflation layer justin CFX 5 April 12, 2007 08:28
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
