October 23, 2012, 04:14 |
save smoothed mesh
mohamed khedr emam
Rep Power: 14 |
Hi All,
I have small inquiry How to save the mesh after smoothing , if I back to "Display Mesh Quality" I found the old un-smoothed mesh even I save the mesh after smoothing !! Thanks in advance |
October 24, 2012, 02:08 |
mohamed khedr emam
Rep Power: 14 |
any suggestion
October 24, 2012, 18:32 |
Ghazlani M. Ali
Rep Power: 28 |
may be you have prism in your mesh. when you freeze penta-6 to smooth everything else, you get a quality bars. that shows you the quality of all the other elements exept the penta-6. so when you go back to check the quality again, you do that for all the element. It's not comparable. freeze penta-6 in both you will notice that quality bars are same.
November 1, 2012, 09:32 |
mohamed khedr emam
Rep Power: 14 |
Thanks diamondx for replay
yes , I used "freeze penta-6" option when smoothing the mesh I appreciated your note thanks again |
How can I save a mesh file in ANSYS Workbench V12 for standalone mode CFX-Pre? | fkonias | ANSYS Meshing & Geometry | 22 | March 18, 2017 09:38 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
