Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] Negative value for Enclosure Cushion
Old   November 1, 2012, 11:17
Default Negative value for Enclosure Cushion
siw
siw will become famous soon enough
I want to make an enclosure around a body to get the fluid volume. However, I need one end of the enclosure to align with one end of the body because the front of the body would make the mesh too large. For example: make an enclosure around an aircraft but starting it along the fuselage behind the nose rather than including the nose and upstream air, forget the fact about needing the upstream air for the CFD.
Any ideas how this can be done since we cannot set cushion values less than 0?
Thanks
siw is offline   Reply With Quote
Old   November 1, 2012, 12:44
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
don't use enclosure, extrude a FROZEN rectangle then and slice...
Regards,
New to ICEM CFD, try this document --> http://goo.gl/G2gkE
Ali
diamondx is offline   Reply With Quote
Thread Tools
Trackbacks are On
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 12 December 12, 2011 05:16
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
