Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] Section view - Diving into two parts
Old   November 2, 2012, 03:57
Default Section view - Diving into two parts
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Dear
How can I view the internal parts in DM. In other words I want to divide the geometrical model (360 deg) into two parts at the symmetry plane as I usually do in Pro-E and then hide the one half in-order to have a clear view of the internal parts.
Far is offline   Reply With Quote
Old   November 2, 2012, 09:04
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
click tool -> freeze then go to view and check frozen body transparacy.
You can click on seperate bodies and use right button then hide them.
i can help you with the symetry too, let me know if you're having problem with it...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Old   November 3, 2012, 02:53
Far
Sijal
What is difference between small face and sliver face?
Old   November 3, 2012, 08:33
diamondx's Avatar
Ghazlani M. Ali
i don't know what you're talking about .... where did you see that
Regards,
Ali
Old   November 3, 2012, 08:37
Far
Sijal
I figured out the problem by using the symmetry command.
The sliver face and small face is the term used in the offical ANSYS DM training presentation.
Old   November 3, 2012, 08:41
diamondx's Avatar
Ghazlani M. Ali
decided to play a little bit with designmodeler ??
Regards,
Ali
Old   November 3, 2012, 08:49
Far
Sijal
Yeah and I felt it is much more comfortable to work little in DM before taking the model into ICEM.
Though ICEM has very good geometric features but not powerful as Gambit. So I usually work in Gambit to get the required geometric shape before taking it into the ICEM, but Gambit has few problems, e.g. the version I am using has the license upto 11 Nov 2011 and I have to change the date every time I run it. Moreover in my license, IGES/step are the only option to import the model. Sometimes I have files in workbench format and sometimes in parasolid. So I thought to give a try to DM this time and see how I can get the things, I usually get in the Gambit.
I also like the space claim way of working.
Old   November 3, 2012, 15:09
Far
Sijal
The sliver face and small face is the term used in the offical ANSYS DM training presentation. Any body has idea what is difference between them?
Old   November 3, 2012, 15:52
diamondx's Avatar
Ghazlani M. Ali
https://www.sharcnet.ca/Software/Flu...irSlivers.html
Regards,
Ali
Thread Tools
Trackbacks are On
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 25 June 27, 2016 00:58
Links Section - Major Update! pete Site News & Announcements 0 February 6, 2012 08:51
LiftDrag utility from v12 to v141 cfdphil OpenFOAM Running, Solving & CFD 2 December 5, 2007 06:49
How to view through a section? Harendra FLUENT 1 January 25, 2005 08:43
