Invert geometry
Hi all.
Does anybody know if it is possible to invert this geometry, so I get only the fluid part? The assembly shows a nozzle with 3 inlets and one outlet. https://dl.dropbox.com/u/19953951/nozzle.PNG Or is it preferable to put this geometry as it is into cfx and comsol, which I am going to use for my analysis? The geometry is drawn in Solidworks Thanks |
you can do that in pretty much all the cad software. in designmodeler, you just close all the hole and use the fills by caps option. if you don't know how to close the holes, you can use "fill by cavity".
Another way to do that will be to extrude a frozen body, and do a boolean operation. Give it a try in designmodeler, it's very easy, come back if you are stuck i will gladly help you... |
Hi.
Thanks for your answer. I couldn't really get the fill by cavity to work, because I had to click on every face inside my geometry and I think I missed some of them every time I tried. But I figured out how to close the holes by 'surface from edges' and the I used the 'fill by caps' :D |
| All times are GMT -4. The time now is 16:45. |
