November 7, 2012, 11:04 |
Bug in DM
I am working on some youtube tutorials where I want to make the Hexa meshing in ICEM on the gambit meshing tutorial (know as sedan tutorial). I wanted to make the some repairing work in DM on sedan , but I am surprised to see that DM is making more issues, whereas Gambit is perfect. I have also tried in ICEM with no errors.
Any one knows what is the problem with DM? Gambit: Design Modeller: ICEM: |
November 7, 2012, 11:09 |
Here you go
https://dl.dropbox.com/u/68746918/sedan.igs See this thread and post #12 (same case in ICEM : tetra + prism) http://www.cfd-online.com/Forums/ans...d-pl-help.html |
November 7, 2012, 13:01 |
Ghazlani M. Ali
Rep Power: 28 |
OK, may be i have a clue.
The default import option in designmodeler includes "stitch surface" as yes Switching it to no resolves the problem. that is may be due to designmodeler trying to stitch a complex set of surfaces... |
November 7, 2012, 13:28 |
#9 |
I mean, can you repair the missing surfaces, sliver faces, short edge and other problems in sedan cad model (I just shared on forum) in DM.
I see more problems as compared to gambit and ICEM in DM |
November 7, 2012, 14:41 |
#11 |
Ghazlani M. Ali
Rep Power: 28 |
ok, this is what i've done so far:
i removed some very bad surfaces that were merged to the ones next to them i recreated them using edges: I did a "sew" with a very small tolerance (10e-6 if project was imported in meter) Did the same for the back, noticed that surface is not really what i want, but i think that can i be solved if i used a split and did it in two step instead of one: Last surfce is created so i can perform a fill... of course sew has to be done in each steps there may be a easier way of doing this... hope i can discover it in the future when dealing with other geometries |
November 7, 2012, 15:51 |
Questions
#13 |
Two questions come into mind:
1. Why in first palce DM had the errors, when gambit and ICEM didn't 2. After repairing are you sure that they are original surfaces? |
November 7, 2012, 15:57 |
#14 |
Ghazlani M. Ali
Rep Power: 28 |
i don't know how gambit works... because your iges contains surfaces, and since icem cfd is a surface based mesher, it didn't find any difficulty dealing with. DM includes solid and surface, you gave it a hard time maybe ?!
After repairing , the original surfaces are merged and sewed into a new one. sorry for not being clear here it's first and only things it came to my mind |
November 7, 2012, 15:59 |
#15 |
Gambit is solid direct modeller and works on solid as DM. And that IGES was a solid model and ICEM converted it into surfaces by default.
If that model was not solid then DM would have the surfaces only. |
November 7, 2012, 16:19 |
#18 |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 14:11 |
Serious bug in LES interface | fs82 | OpenFOAM Bugs | 21 | November 16, 2009 08:15 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
Bug reports | Mattijs Janssens (Mattijs) | OpenFOAM | 0 | January 10, 2005 10:05 |
Forum y2k Bug | Jonas Larsson | Main CFD Forum | 1 | January 5, 2000 10:22 |
