[GAMBIT] Problems while meshing a 3d CAD model |
November 6, 2012, 04:41 |
Georgi Angelov
Hello all CFD's users,
I have a problem while meshing a imported 3d CAD model.The model is for HVAC simulation and the Inlets are at the top and the oulets are at the botom of the model. First I tried to imported is an iges file but when i choose a spatial import options and make all the options that I have read in the gambit(ansys) user guide, nothing happens I clicked accept and there is nothing on the screen. Next I tried to imported it again as an iges but a "native" import options this works but no volumes where recognised and the model is a little bit grey it is not colored well. Next I tried to import it as an acis file and it works best. I have one volume recognised, all the faces are also recognised. So I started to mesh it - first to mesh the volume and next the inlets,outlets and walls. Meshing the volume- the process starts but at the middle of it an error appears on the screen and it says: "That a fatal error has occurred.It is not possible for GAMBIT to continue from this point.Please contact your local fluent officer..... ". The only way to mesh the volume is with stairstep mesh,but this mesh is not complete and there are only 5 or 6 zones meshed in the whole model,so the only option for me was the stairstep despite of the mesh is not complete but it works somehow. Next meshing the outlets,inlets and walls- It works I meshed it with Tri-Pave 0.05. I made all the boundary types-the inlets with velocity inlets,the outlets with outflow and the walls. When I export the mesh and opened it in fluent and click grid-check- Errors appeared- Skipping all the outlets and inlets(not referenced by grid) and when I click display grid-the only grid that appears is the Volume-stairstep grid. My questions are: I have to clean the geometry,because it is too complex for gambit to mesh it? 2.Why fluent can not recognise the outlets and inlets grid despite of the fact they are meshed. I have upload the cad file and the iges and sat file.Thank in advance. |
November 6, 2012, 04:58 |
Georgi Angelov
November 6, 2012, 05:55 |
Maxime Perelli
Rep Power: 41 |
If nobody helps you until friday, I will check it at the office (still in vacation )
In memory of my friend Hervé: CFD engineer & freerider |
November 6, 2012, 06:22 |
Marion
You can try cutting your volumes into smaller volumes in order to find out where the problem is located. IT is also a good way to control the mesh. Marion. |
November 7, 2012, 02:33 |
Georgi Angelov
Thank you for your replies!
Marion- I have tried to clean up the geometry and split in some volumes,but it is still complex and the program give errors. I'm thinking to start using Ansys, but I don't have time now to learn it because I need the analysis of the hall in days.My task in the University is for the next week, so I'm running out of time. Max- I will be very pleased if you can help me after your vacation.Enjoy it and all the best. |
November 9, 2012, 01:51 |
Maxime Perelli
Rep Power: 41 |
you have very thin entities in your model.
You will have to do some splits for meshing it with acceptable quality
November 9, 2012, 11:57 |
Georgi Angelov
Thank you Max, I have made the volume again but I had some problems. I want to make it a single volume from all the faces with stitching and then to try meshing the volume. There is an error message: "Cannot create an Acis body. Is this an open shell?". I saw earlier thread in which you said that you have to click on shaded mode to see where are my missing faces,but I cannot see any holes in the model. Here is the model, I will be very pleased if you can see where are the missing faces for creating the volume.The model was made in Autocad 3d from surfaces and regions.
November 9, 2012, 11:59 |
Georgi Angelov
November 12, 2012, 00:49 |
#10 | |
Maxime Perelli
Rep Power: 41 |
November 12, 2012, 03:35 |
#11 |
Georgi Angelov
November 12, 2012, 03:51 |
#12 |
Maxime Perelli
Rep Power: 41 |
the import generates the volume automatically
November 13, 2012, 04:32 |
#13 |
Georgi Angelov
http://www.2shared.com/file/cRB4WANR...ri_opit-1.html but when I import this file with file/import/acis gambit only recognise 114 faces but no volumes,and when I try to createa volume from wireframe or faces,there is a problem.
November 13, 2012, 04:38 |
#14 |
Maxime Perelli
Rep Power: 41 |
With your last sat file, yes I also have 114 faces.
But with your first sat file, I get a volume (Gambit 2.4.6)
November 14, 2012, 08:44 |
#15 | |
Georgi Angelov
My steps in fluent are: 1.File/Read/Case-Hall.msh 2.Grid/Check 3.Display/Grid 4.Define/models/solver-Pressure based and Implicit 5.Define/models/viscous- K- epsilon 6.Define/models/energy-energy equation 7.Define/materials-air 8.Define Boundary Conditions- Velocity inlets Top- 5 m/s and 306 K Velocity inlets wall-7 m/s 293 K Walls- Temperature 293 K Outlets-Flow rate weigthing - 1 Hall- Volume-fluid 9.Solve-Controls-Solutions Flow and Turbulunce , Second order upwind 10.Solve/monitor/residiuals - plot 11.Solve/Initialize/init 12.file/write/case 13.Solve/Iterate 1.Is this Outflow error from the reason that we haven't put all the air terminals in the hall? because we want to try and then to draw them all,because they are about 350 air t., 2.May be somewhere in the boundary conditions we are missing something? 3.May be in the mesh it has to be with more precise? Here are some pictures and the .msh and .dbs files.I will be very pleased if somebody helps me. |
November 14, 2012, 09:02 |
#17 |
Maxime Perelli
Rep Power: 41 |
reversed flow isn't a huge problem.
You may let iterate, and it can disappear. You could also use pressure-outlet instead of outflow. Important is to check the convergence. You can also monitor a value like the pressure at your inlet
November 14, 2012, 09:41 |
#18 | |
Georgi Angelov
Erorr object: (). I checked the convergence criterion and made it 0.01. I change the outflows to presure outlets and the error is the same. Is the problem from the continuity line, or may be if I put all the air terminals in the hall may be it will go down or ? |
November 15, 2012, 07:58 |
#19 |
Maxime Perelli
Rep Power: 41 |
*any errors or warning in the check Mesh?
*is mass conservation respected (massflow in = mass flow out)? *before iterations break, display velocity contour, and check if it well flows *check also if you don't have other boundaries as yours, which appear (wall-shadoww, or whatever)
December 29, 2012, 06:48 |
gambit sudden crash
#20 |
Aathavan
Hi every one,
I am facing strange problem in Gambit, while creating the geometry in gambit. The sudden crash is happening often middle of my work, I dont know what is the reason. I have attached the error message please have a look and give me some idea what to do? Thanks, Aadhavan |
Problems solving T Equation in separated flow using a second Order Closure Model | pascool | OpenFOAM Programming & Development | 1 | November 19, 2012 10:29 |
Tetra Meshing over Frigate Ship Model | rohitsaini@y7mail.com | CFX | 11 | September 3, 2012 14:26 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
CAD model sliver faces - CFX Mesh - Parasolid? | Ianto | CFX | 3 | February 8, 2009 18:32 |
Vehicle CAD Model Meshing | B Bru | Siemens | 5 | June 8, 2007 17:30 |
