-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [DesignModeler] Problems with revolve (axis intersects all profiles) (http://www.cfd-online.com/Forums/ansys-meshing/108982-problems-revolve-axis-intersects-all-profiles.html)
natur3 November 6, 2012 09:24
4 Attachment(s)
Hi all,
I have imported a coordinates file to create a 3D curve. It will close up the curve. When i tried to revolve a line body along an axis, it will give me an error telling me that my axis intersects all profiles. I'm trying to create something like a "bowl".
But when i create points and revolve, it can give me the "bowl" shape. But its not a surface. How can i solve this?
Thanks alot!
I have attached the coordinates file.
Attachment 16675
diamondx November 6, 2012 11:00
can you share your agdb file... your project after revolving ?
jrunsten November 6, 2012 11:19
You can't revolve something that extends across the axis of revolution. In this case, both negative and positive values of z and x exist. I imported only the first 53 points and was able to revolve the line body. I closed the center with a surface patch. If you wan't to create a surface more exact than that, which involves all of your coordinates, I think you will have difficulties in Design modeler.
http://i.imgur.com/RQrRR.png
natur3 November 7, 2012 05:21
I have attached my projects after revolving.
https://www.dropbox.com/s/biix2j3zhm...Geom_line.agdb
https://www.dropbox.com/s/ur6hc1xowm...eom_point.agdb
Why the 1st 53 points? How do you get that?
jrunsten November 7, 2012 05:31
Simply because the first 53 points describes one of the slopes from beginning to the (almost) axis. I bet you could do the same with point 54-105, or somewhere around that number, but it was more convenient to choose the first since i didnt need to change the point numbers in the point list.
Done simply by opening the text file and deleting the rest of the points. Now if you do this and the import all of the points as a curve again you can see that the "bowl" represent these points pretty well, but it's not perfect:
http://i.imgur.com/IpqiF.png
natur3 November 7, 2012 06:36
I see.
So if I want to be more accurate, I have to get the points from the beginning to exactly at the axis?
jrunsten November 7, 2012 06:41
Well yeah, but other than that, the rest of the points won't be represented (in case it's not completely axisymmetric, which it doesn't look like). If you revolve another 8th of you point set, you might get a different surface. What data is it anyway? Measurements of some kind?
natur3 November 7, 2012 07:13
I see,
Its actually the outer cornea of a human eye. (From optical coherence tomography images)
I still have the other parts of the eye to model, eg, iris, inner cornea,etc
Since I'm still learning ANSYS, I was thinking to start from the outside, and continue to model the rest after I have model 1 part.
natur3 December 14, 2012 07:13
I have managed to remove the connection of the lines. Now i have 4 individual lines and if possible I want to revolve this 4 lines into one single surface as it will be more accurate.
http://i114.photobucket.com/albums/n...psbd14aa9e.jpg
jrunsten December 14, 2012 07:43
Can't be solved using a Revolve. Maybe someone has some suggestions, but I think you need another tool rather than Design Modeler.
natur3 December 14, 2012 07:53
Other tools?
So far, I only know autocad and ansys can construct 3d models.
Anyone has any other suggestions/software?
saeed bahrami July 16, 2014 06:31
pls help me to ansys-cfx-designmodeler
Hi
how to design figure 1,2 ?
i drew figure 3 .
I want figure 3 Circumference of a circle.
how to do ??
pls help me
thanks a lot
saeed.bahrami91@yahoo.com
http://www.uplooder.net/img/image/12...d/Untitled.png
