Home > Forums > ANSYS Meshing & Geometry
[ICEM] Meshing prob at the surface joint
Old   November 13, 2012, 06:27
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
did u make the association?
Far is offline   Reply With Quote
Old   November 13, 2012, 06:38
S.Bogoda
sakurabogoda is on a distinguished road
Dear Far,
Yes I did. As you can see there is a connection with cone and the cylinder. Cylinder is extending into bottom. (Actually the geometry is a cyclone separator)
I used two blocks (merged) to block them.
sakurabogoda is offline   Reply With Quote
Thread Tools
Trackbacks are On
[DesignModeler] Sweeping or surface meshing in enclosure? Edu-R ANSYS Meshing & Geometry 9 January 23, 2013 14:41
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 11:52
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 0 August 5, 2011 16:02
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
boundaries with gmshToFoam‏ ouafa Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 May 21, 2010 12:43
