November 22, 2012, 12:11 |
2D refinement problem
Rep Power: 15 |
Dear Icem CFD users,
I want to refine a 2D geometry partially and export the mesh into fluent. Here is simply what I tried: I drew a rectangle divided in half by a curve, constructed hexa block mesh and refined one half by Blocking->Pre Mesh Parameters->Refinement. The result is as shown on the first figure. However, when I try to import it into fluent, this error message is returned: Clearing partially read grid. 451 nodes. 324 quadrilateral cells, zone 15. 81 quadrilateral cells, zone 16. 612 2D interior faces, zone 17. 144 2D interior faces, zone 18. 18 2D interior faces, zone 19. 54 2D wall faces, zone 20. 27 2D wall faces, zone 21. Building... mesh Warning: Inappropriate zone type (interior) for one-sided face zone 19. Changing to wall. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f Is this a general type of error people see in 2d refinement? |
November 22, 2012, 13:04 |
Rep Power: 15 |
Thank you for your response, I did what you suggested however I got this error:
Building... mesh Cell Centroid is xc 42.129630 yc 4.166667 WARNING: no face with given nodes. Thread 20, cell 0 Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error. Error Object: #f Error: CAR: invalid argument [1]: wrong type [not a pair] Error Object: () The coordinates are in the left half |
November 22, 2012, 13:12 |
Ghazlani M. Ali
Rep Power: 28 |
it is due to uncovered face. if you google the no face with given nodes error, you will get a lot of thread about it.
Your problem is not a major one, something happened there, try redoing your bloing after the bodies are created, also make sure the associations are done... |
November 22, 2012, 16:10 |
Rep Power: 15 |
Thank you but I don't think that's the problem because the unrefined the block can be imported into fluent without error.
Here is what i did in order: Drawing the geometry, 2d planar blocking, Dividing the block and adding the blocks to left and right material points separately, adjusting the edge parameters. Any step I might be skipping? |
November 22, 2012, 17:54 |
what is the ratio of refinement?
See the post # 63 http://www.cfd-online.com/Forums/ans...linders-4.html |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
Problem/ bug in mesh.cellCells() ?? | daZigeiner | OpenFOAM Bugs | 2 | May 18, 2015 15:54 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[ICEM] Problem with hexa mesh refinement | John Doe | ANSYS Meshing & Geometry | 2 | March 18, 2011 09:04 |
[snappyHexMesh] sMH refinement level | subhkirti | OpenFOAM Meshing & Mesh Conversion | 0 | October 13, 2010 04:10 |
