[ICEM] 2D refinement problem
Old   November 22, 2012, 12:11
Default 2D refinement problem
highhopes is on a distinguished road
Dear Icem CFD users,
I want to refine a 2D geometry partially and export the mesh into fluent. Here is simply what I tried:
I drew a rectangle divided in half by a curve, constructed hexa block mesh and refined one half by Blocking->Pre Mesh Parameters->Refinement. The result is as shown on the first figure.
However, when I try to import it into fluent, this error message is returned:
Clearing partially read grid.
451 nodes.
324 quadrilateral cells, zone 15.
81 quadrilateral cells, zone 16.
612 2D interior faces, zone 17.
144 2D interior faces, zone 18.
18 2D interior faces, zone 19.
54 2D wall faces, zone 20.
27 2D wall faces, zone 21.
Building...
mesh
Warning: Inappropriate zone type (interior) for one-sided face zone 19.
Changing to wall.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error:
Error Object: #f
Is this a general type of error people see in 2d refinement?
highhopes is offline   Reply With Quote
Old   November 22, 2012, 12:36
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
you could do that without separation by a curve. try creating a body in your right too. see if it can solve the problem...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 22, 2012, 13:04
Thank you for your response, I did what you suggested however I got this error:
Building...
mesh
Cell Centroid is xc 42.129630 yc 4.166667
WARNING: no face with given nodes. Thread 20, cell 0
Error: Build Grid: Aborted due to critical error.
Error Object: #f
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
The coordinates are in the left half
Old   November 22, 2012, 13:12
diamondx's Avatar
Ghazlani M. Ali
it is due to uncovered face. if you google the no face with given nodes error, you will get a lot of thread about it.
Your problem is not a major one, something happened there, try redoing your bloing after the bodies are created, also make sure the associations are done...
Regards,
Ali
Old   November 22, 2012, 16:10
Thank you but I don't think that's the problem because the unrefined the block can be imported into fluent without error.
Here is what i did in order:
Drawing the geometry,
2d planar blocking,
Dividing the block and adding the blocks to left and right material points separately,
adjusting the edge parameters.
Any step I might be skipping?
Old   November 22, 2012, 17:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
what is the ratio of refinement?
See the post # 63 http://www.cfd-online.com/Forums/ans...linders-4.html
Far is offline   Reply With Quote
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
Problem/ bug in mesh.cellCells() ?? daZigeiner OpenFOAM Bugs 2 May 18, 2015 15:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[ICEM] Problem with hexa mesh refinement John Doe ANSYS Meshing & Geometry 2 March 18, 2011 09:04
[snappyHexMesh] sMH refinement level subhkirti OpenFOAM Meshing & Mesh Conversion 0 October 13, 2010 04:10
