[GAMBIT] How to geometry and meshing my model
Old   November 21, 2012, 00:03
Default How to geometry and meshing my model
benny95
lalolala is on a distinguished road
Dear all,
im kind of new user of GAMBIT and FLUENT. anybody can help me to build this model for me?
i can build the geometry but having problem to do the meshing.
is look like heat exchanger with simple dimension. the fluid flow inside should be crude and the fluid between the inner pipe and outer pipe is water circulation from inlet to outlet.
can further email in at bennybenn95@gmail.com
lalolala is offline   Reply With Quote
Old   November 21, 2012, 01:05
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
what is your problem with meshing?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 21, 2012, 01:51
benny95
below picture if my model...and its look like this when i trying to mesh...
i appreciate if anyone can help me on this matter..
Old   November 21, 2012, 01:56
-mAx-'s Avatar
Maxime Perelli
can you enable the shaded mode on and repaste a picture?
Old   November 21, 2012, 02:09
benny95
u means like this?
Old   November 21, 2012, 02:16
-mAx-'s Avatar
Maxime Perelli
ok
Now you create a (yz) surface big enough to be sure that it will cut your geometry.
you move it till middle of your geometry and you split the volume.
Delete one half and again shaded mode on, and post picture (you will see how it looks like in your domain)
Old   November 21, 2012, 02:18
benny95
will try it later..later i will post again here..thanks for ur guidance..
Old   November 21, 2012, 02:21
-mAx-'s Avatar
Maxime Perelli
wait!
your error is simply because you are trying to mesh your volume with hex-cooper.
And for sure you cannot.
Try with tetra-hexcore
Old   November 21, 2012, 05:48
benny95
ive done meshing using tet/hybrid TGrid..successful..
but my concern, how am i gonna put thing like
Inner pipe - Copper
fluid 2 - crude
Outer pipe - steel
fluid 1- crude
how am i going to set the boundary cond?how am i sure that its gonna be like pic 2 attached. how to make sure that the water flow inlet and goes out to the outlet can transfer heat to the product pipe?
kindly help...im going to present this project very soon and now i really running out of time..
Old   November 21, 2012, 06:03
-mAx-'s Avatar
Maxime Perelli
if both fluids are not going to be mixed, then you should have to seperated fluid volume. Then you need to define a fluid zone at both domains (but not same fluid zone else the solver will understand it is only one fluid)
For heat transfer, I have no experience but look at shell conduction http://aerojet.engr.ucdavis.edu/flue...e253.htm#33058
Old   November 21, 2012, 06:14
benny95
ok...means i no need to subtract the inner pipe and the outer pipe? and just set the fluid contain inside?
how about the heat transfer surface, its going to be like 2 different layers, isnt it?
Old   November 21, 2012, 06:19
-mAx-'s Avatar
Maxime Perelli
do the trick with cut-plane to see how it looks like in your domain
I am not sure, but I believe you have to disconnect both volumes at this surface. Gambit will create 2 superposed surfaces and you gonne treat them as 2 different layers.
>> again here I have 0-experience
Old   November 21, 2012, 06:23
benny95
alright2...i will try my best...
anyway, thanks for ur respond..
Old   November 24, 2012, 10:42
benny95
i did the shell conduction...i do have only 1 ting layer between 2 fluid.. but i didnt get the result i want.. the temperature still not influence the inner fluid..its like there is a boundary, a resistance that not allow the temperature distributed inside the fluid..
any idea?
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry robbierich90 ANSYS Meshing & Geometry 0 October 30, 2011 13:12
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 26, 2011 23:25
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 11:15
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
