hydrocyclone Mesh Quality.
https://docs.google.com/open?id=0B1F...EplUG4zVFVaOUk
Hi Everyone, I’m working on the meshing of hydrocyclone with gambit. I finished the mesh but would if anyone can advise me if my work in correct or these is some lacks? I went to mesh exam and set to range from 0.9 to 1, there are 5 grids appeared in face 14. Should I change the geometry by lifting this face or I can use sweep face in the z direction by 1 unit. For all volumes I set the aspect ratio by 1, should I change it to 0.45? Note: this work is a two phase flow (water contains sand particles). I meshed all faces by Hybird/Tgrid. please see attached file in the link below on google documents: https://docs.google.com/open?id=0B1F...0hSR0xKdGpPbW8 Highly appreciate any assistance Thanks for Mr. mAx for assisting me. Osamah Al-Hashimi |
your link doesn t work
1 Attachment(s)
Here the link sir ... it is the same file i sent you before and you checked it ...
I just like to view the procedure for solving the two problems you spcificed. is this procedure oK? https://docs.google.com/open?id=0B1F...0hSR0xKdGpPbW8 REGADING the aspcet ratio, Please see attached pic when i change the Aspect Ratio from 1 to 0.45 ... can i keep the Aspect ration by 1? Thank you Attachment 17328 |
1 Attachment(s)
Again your problem are only on edge 5, edge 9 end edge 12
You can fix your both first issues by giving more nodes on edge 5 and edge 9 Edge 12 issue can be fixed if you sweep face 14 in z-direction (small vector). Then sharp angle at vertex 12 wil disppear if you suppress edge 12 (by merging surface 8 with new surface from sweep) Attachment 17349 |
3 Attachment(s)
Many Thanks Freind
These problems appears when I try to merge face 8 with the new face from the sweep (face 20) Error: Tried to merge faces face 8 and another from the list that are not connected. I tried face 14 with 20 … same error appeared. I tried face 8 & 14 & 19& 20 … this error appeared: Error: tried to merge faces face 8 and face 19 with different upper topology or with nonmanifold neighbors (share the common boundary with another face). Attachment 17356 Attachment 17357 Attachment 17358 |
before you merge both surfaces, you need of course to merge both volumes
2 Attachment(s)
Thank you very much
I merged the two volumes … a v_voulme.6 created … mesh is done but is it ok? Attachment 17359 Attachment 17360 |
examine mesh and check quality (skewness < 0.9 should be ok for tetra mesh)
1 Attachment(s)
it is 0.74 ... Please see attached picture.
Is the vertual volume a problem? Many thanks sir for your time and for advicing me ... thank you very much Attachment 17361 |
should i change the vertual volume to real? can i say that i have accepted quality mesh to work on a two phase flow in fluent.
many thanks many times |
virtual isn t a problem
you can go and solve |
Thank you verrrrrrrrrrrrrrrry much ... god save youuu.
Hi, i made a new geometry ... and re meshed it in Gambit
In Fluent i made a <report quality> for both meshes , i got this results: Mesh Quality (for the geomety you assisted me in): Mesh Quality: Applying quality criteria for tetrahedra/mixed cells. Maximum cell squish = 7.24566e-001 Maximum cell skewness = 9.54236e-001 Maximum aspect ratio = 1.65974e+001 *************************************** Mesh Quality for the geometry i made (the new one): Applying quality criteria for tetrahedra/mixed cells. Maximum cell squish = 7.24566e-001 Maximum cell skewness = 9.54236e-001 Maximum aspect ratio = 1.65974e+001 is there a problem in the Maximum cell skewness of the second geometry? Many thanks freind for your continouse assistance ... |
i have enhanced the mesh of the new geometery, the result is:
Mesh Quality: Applying quality criteria for tetrahedra/mixed cells. Maximum cell squish = 7.24566e-001 Maximum cell skewness = 7.92745e-001 Maximum aspect ratio = 1.65974e+001 I think it is much better ... Many thanks mAx :D |
Quality should be ok. Since you don't get a "Grid Check Failed" you can go and solve.
