Home > Forums > ANSYS Meshing & Geometry
[ICEM] Rotating of a 2D Blocking
Like Tree6Likes
Old   November 30, 2012, 18:51
CFD_SIM is on a distinguished road
Thank you very much!
I will take a look at your changes on monday.
Was there a lot to change in my initial blocking? From the picture i see that you reduced the nods and i think you deleted the spacing. Was that the problem?
Greetings
John
CFD_SIM is offline   Reply With Quote
Old   November 30, 2012, 23:13
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
Hi Ali
Did you make this blocking using command 2d-3d with rotation option? As I am not succesful getting this command work.
Far is offline   Reply With Quote
Old   December 1, 2012, 03:24
Far
Sijal
Steps to make the 2d blocking for the symmetrical channel and then subsequent conversion to 3d mesh using the ICEM Command : Create block > 2d to 3d > method 2d to 3d
The general procedure is :
1. Make the appropriate points and curves at one location, let say at 0 deg. This is used to hold the initial blocking.
2. Points were made at the 4 corners. Two were already available, so extra two points were created at the two opposite corner.
3 2d blocking was initialized.
4. Association was made at the four corners points as discussed in step 2.
5. Appropriate splits were made and unwanted blocking was deleted.
6. Association of edges to curves and vertex to points were made.
7. Some extra points were also created to hold the blocking at the proper locations.
5. Edge mesh parameters were set and premesh was inspected.
6. Now go to create block panel again and choose option 2d to 3d.
7. Set method to rotate.
8. centre should be origin - default option
9. Axis of rotation Z axis
9. Angle = 90
10. Number of copies 4 so it will make the blocking in 4 step with each step of 90 deg, If you select the angle = 45 then you should increase the no of copies to 8
11. Points per copy =30 or whatever value you want. This will make the nodes per edge = 30 for each 90 deg. so total number of nodes on full circumference shall be 30*4 = 120.
12. Create part curves and put all curves in this part and similarly for the points. This is necessary for the boundary conditions as we are going to define the boundary conditions for the surface (3d case now) and surfaces must not contain the edge or points.
13. Select solver Ansys-Fluent
14. Give boundary conditions.
15. Convert premesh to unstructured mesh by right clicking on the premesh and choosing the option convert to unstructured mesh.
16. Output the mesh and read in the Fluent.
17. Check the mesh quality in Fluent.
Three set of files are attached.
1. Raw blocking (step1)
2. 2D blocking (step2)
3. 3d Blocking (Final)
https://dl.dropbox.com/u/68746918/2d-3drotation.rar
Note : Original idea is by diamondx
diamondx likes this.
Old   December 1, 2012, 12:47
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Not at all, just run an update with fix blocks... this is why the number of node was initialized. Always try it when you feel lost in your blocking.
yes FAR i used that command... made 4 copies with 90 angle...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is online now   Reply With Quote
Old   December 3, 2012, 10:56
what exactly do you mean by "run an update with fix blocks". Do you mean, that i just should adjust the vertices or is it an actual button that i can't find.
I tried it today with my initial blocking and went on like far wrote here, but i still have the same problem with the mesh. Boundarys are showen, but there are still elements overlapping.
I hope that i will have more time tomorrow evening to look at the problem.
Old   December 3, 2012, 13:52
diamondx's Avatar
Ghazlani M. Ali
Yes it is a button, in the pre-mesh tab... depending on which version of icem you have the version 14 include an update with a "fix" feature that you can check.
In version 13, there is only an update button while you can do a fix in another tab...
Regards,
Ali
Old   December 4, 2012, 03:45
I'am using the version 14.5.
Do you mean the button "Edit Mesh" --> "Check Mesh"?
This one i tried, but it only fixes some problems, but not all. Or is there another button, which i did not see.
Old   December 4, 2012, 07:51
Far
Sijal
see this
https://dl.dropbox.com/u/68746918/2dto3d.mp4
I tried on youtube but no success.
PS. Please wait few hours, before that you may get the error 404
CFD_SIM likes this.
Old   December 4, 2012, 12:49
Far
Sijal
CFD_SIM, the bad quality is due to the your initial 2d blocking. Try to improve it
Old   December 4, 2012, 16:40
Thanks a lot!
The video is really helpful. I did not use the additional points, so that may be something that made some of the bad quality.
I will try a new initial blocking tomorrow and hope that it will look better.
It seems, as if there would not appear a good quality if i only associate the points to the vertex eg.
Would be nice of you, if you could let the video online for a while :-).
Old   December 4, 2012, 23:03
Far
Sijal
Yes, only association to points will give you many errors, like uncovered faces etc. It is must to associate the edge to curves for the proper definition of boundary conditions.
Old   December 4, 2012, 23:31
Far
Sijal
It is for ever. I believe in sharing the knowledge
Part I
http://www.youtube.com/watch?v=sIEEz...ature=youtu.be
Part II
http://www.youtube.com/watch?v=b-T0c...ature=youtu.be
Part III
http://www.youtube.com/watch?v=Ygcda...ature=youtu.be
All Parts in one clip:
http://www.youtube.com/watch?v=JxUnE...ature=youtu.be
diamondx, sharonyue and CFD_SIM like this.
Old   December 5, 2012, 03:02
Thanks a lot!
Of course i meant that i've done the associations edge to curve, too.
I will look at my initial blocking and hope that i will find the problem soon :-).
Old   November 18, 2015, 12:08
Filippo
filas91 is on a distinguished road
Hello everybody, i'm new to ICEM. I watched the videos about "2d to 3d blocking by rotation" and i have a simple question:
which kind of part is the one called "FLUID"? I mean, does it includes curves, surfaces etc ?
filas91 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problems with rotating machinery (Centrifugal Pump) in FLUENT RR2 FLUENT 1 January 17, 2016 06:23
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 07:14
