[ICEM] Problem in creating different zones in ICEM-CFD
Like Tree1Likes
  • 1 Post By diamondx
Old   November 28, 2012, 04:34
Unhappy Problem in creating different zones in ICEM-CFD
samurai_01 is on a distinguished road
Hi everyone.
I am a beginner in ICEM CFD. my problem is that i have been solving a problem of fluid flow through microchannel in 2D, with three separate region, two of them being solids and the middle one being the fluid region.
As i am meshing in ICEM CFD:
1. i am unable to use blocking on 3 regions as when i select blocking, it selects the entire entity as a single geometry, which i don't want to.
2. i am creating different bodies for my problem but when i right click and dispaly info, it says there are no curves/surfaces/mesh parts in the body parts created. (say fluid / solid1/solid2).
and when i export the mesh, it displays only one single zone(the default GEOM) and not the 3 zones i want to.
I have attached the image of my figure with zone's names specified and
Please help... i have read many posts and have tried and falied, but to no avail.
samurai_01 is offline   Reply With Quote
Old   November 28, 2012, 08:48
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Use a blocking, after splitting your blocks, right mouse button on part, then create, then click on "blocking material" give the name fluid1 and select the block you want to dissociate from solid...
CFDger likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 28, 2012, 12:41
Smile
THANK you very much for your precious help..... i am trying it out and will let you know the results...
UPDATE:
yes it worked in my model for 2d and for 3d .... thanks for helping out
body, icem 2d, material points
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
[ICEM] ICEM CFD boundary conditions conversion to Fluent problem kalyangoparaju ANSYS Meshing & Geometry 0 October 30, 2011 23:40
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 08:27
ICEM 12 CFD help creating volume mesh from stl EmpError ANSYS 0 November 13, 2010 06:38
ICEM CFD 5.1 problem with tetra count Baskaran CFX 2 March 13, 2006 12:59
