November 28, 2012, 17:57 |
O-grid strategy
christine
Rep Power: 16 |
Hello everyone,
I am trying to mesh a part of a geometry. I would like to use the block strategy or even O-block...but I am a bit lost and really "strange things" are coming out. This is my geometry : http://cjoint.com/?0KCwDA1RElX I don't know how to divide the domain : I've tried many things with no success. I have divided the front plane in 9 (3 x 3 with ref to x by y for example) zones and the lateral plane in 6 (2x3 with ref to x by z) zones so that the internal tube is in the ( 2,2,1) zone. But then when I have to associate, I don't know how to proceed: http://cjoint.com/?3KCwWmveoP9 Thank you for any help yorelchr |
November 29, 2012, 01:49 |
Andrey
Rep Power: 16 |
Can you attach the geometry *.tin?
November 29, 2012, 08:14 |
Andrey
Rep Power: 16 |
I created geometry similar to this.
December 1, 2012, 09:23 |
#4 | |
christine
Rep Power: 16 |
ciao Ralen,
sorry for replying so late, but I had some other work to do and now I'm back again to this geometry. I've tried to send it to you but couldn't...I had the following message "invalid file". Well, I tried to do as you did. And I think I did not too bad. But when I try to read the mesh with Fluent I always have : Quote:
I can't see where I'm wrong, the mesh is clean... |
December 1, 2012, 12:16 |
christine
Rep Power: 16 |
Here is the geometry with blocking and meshing.
Can anyone tell me what is wrong with it since I can't open the mesh on Fluent. PS: the mesh is not really good but it's just a try version for testing the compatibility with fluent. thank you http://cjoint.com/?3LbrwbsQqX7 |
December 1, 2012, 14:01 |
christine
Rep Power: 16 |
ciao Far,
thank you for your reply. I don't understand where I should put parameters for periodicity. In the BC panel I've put periodic but there's no way to specify the value of the angle. When I do a mesh without blocking, I can read it in Fluent without specifying anything for the periodic surfaces. How can it be? |
December 1, 2012, 14:28 |
Minor issues :
1. Quality is low. Needed good topology 2. Current topology can also be improved by putting o-grid inside pipe. Major issues. 1. Curves and points were part of surface and this is not good for defining the boundary condition. Put curve into seperate part say curves and points into points 2. Periodicity was redefined. https://dl.dropbox.com/u/68746918/si...lar%20disk.rar |
December 1, 2012, 15:41 |
#9 |
christine
Rep Power: 16 |
1. yes the mesh is quite bad, but it's just for trying (I've spent time yesterday doing a "good" one to realise that Fluent couldn't read it so today I did all the blocking again without taking too much care on meshing).
2. I've put the inside pipe, seems ok for that. 1. About curves and points : I had made 2 parts for that but then ICEM created this "part.00" and put some staff in it: the curves and wall.125 and wall.126... Now I've changed that as you told me. I also checked with the files you've attached. Seems ok. 2. about periodicity: I've created the point (-45, 0,0) as the base point, then axis (1 0 0) with angle 45. But after doing the 4 pairs of points, horizontal lines have appeared as you can see on the picture : http://cjoint.com/?3LbuPedQhPw And still no way to read the mesh in Fluent. |
December 2, 2012, 06:23 |
#10 | |
christine
Rep Power: 16 |
when I do a check geometry, ICEM automatically recreates me this part.00 with curves from the inside pipe and with wall.125 and wall.126. Can it be a problem with that, for example "double curves" ?
When trying to read the mesh in fluent I have also: Quote:
Any clue? thanks a lot in advance |
December 2, 2012, 11:14 |
#11 |
christine
Rep Power: 16 |
ok problem solved !!!
when coupling points for periodicity I was taking 4 points not on the same surface but on 2 adjacent surfaces. thank you very much for your help!!! |
Display Modes | |
[ICEM] o grid blocking strategy? | icemaniac178 | ANSYS Meshing & Geometry | 14 | March 20, 2013 00:18 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
