December 2, 2012, 09:01 |
about hexagonal mesh
sinykim
hi
I'm getting problem with meshing. Max skewnesses of meshing result are always around 0.99 and I think it makes trouble in Fluent. I heard from someone that there is a option about shape of mesh in mesh software. And he told me that if it is set to hexagonal, max skewness of mesh can be very lowered than when it is set to triangle or square. He said it is somewhere around upper menu bar. But I can't find where that option is. Is there anyone knows the option what I finding and where it is? My Ansys version is 13. |
December 3, 2012, 12:25 |
Simon Pereira
Rep Power: 47 |
It sounds like you are talking about changing your meshing method from the default to Hexahedral...
To do that, select a body, right click and "insert method"... This will pop up a details panel that lets you change the method from default to something else, (like sweep or MultiZone or hexa dominant (for FEA)). But I don't think this will fix your quality problem... Usually quality problems are the result of geometry that over-constrains the mesh. The solution will probably be virtual geometry to remove feature lines that you don't need. A picture of the poor quality areas would be helpful in diagnosing what you need to do.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Display Modes | |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
